Question about Ovens
My oven wont quit beeping!
I have a kenmore oven that wont quit beeping. Out of no where it starting flashing F7 and beeping. Finally i just turned unplugged it. It would quit if i hit cancel, but only for 30 seconds or so. I cant seem to find anyone who knows a thing about it though. beeping and FO indicator
  • Michael Masters
    Michael Masters May 11, 2010
    whats the model number on this unit?
  • Avacado
    Avacado Jan 16, 2014
    I have similar problem with my Ariston FO 87 C IX AUS. The timer (or meter?) keeps jumping/blinking with a loud noise. It would occassionally stop but before stopping, it beeps two or three times before getting still. The whole jumping/blinking thing started again after a short quiet period of time. Any help would be very much appreciated.
  • 338 Answers
If it is an E0-F2 error code then i believe it is for a bad control or keypad.. i would replace both.
Posted on Feb 14, 2009
What do I do about oven beeping?
Could be control module, but not sure. I had issues with a code a long time ago, and the broiler kept coming on and wouldn't shut off, so finally had to shut it off at the breaker. Turns out the control module is fried. But just a thought.
Apr 28, 2015 | Kenmore Double 27" Electric Built-in Wall...
I have a kenmore wall oven that flashes f7 every time we try to use it. and it turns itself off right in the middle of cooking and starts flashing the f7. Help !!!!
Kenmore recommends this:
The display of your control is flashing "F" followed by a number or letter. Oven malfunction. Press the CLEAR/OFF pad. Let the oven cool for 1 hour and place the oven back into an oven operation. If the problem repeats, call for service. 1-800-4-My-Home.
If you state the model #, I can look up the owner's manual for you and give you the link. Let me know.
May 22, 2010 | Ovens
''F7'' Error Code
HI. This is the result of a failed function key. This is an integrated part of the main control board. Unfortunately, this is not repairable, and the main control board will need to be replaced, asap.
Dec 20, 2009 | Kenmore Ovens
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
Kenmore electric built-in oven control panel beeping
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Aug 08, 2008 | Kenmore 42161 / 42169 Electric Single Oven
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Aug 02, 2008 | Ovens
GE Profile Stove
I used what Charlie recommended ...” post-it” as insulation
And works PERFECTLY….
I have a Kenmore oven Clock…( built in the wall)
Thanks Charlie…you are a Genius!!!!
Jul 15, 2008 | GE JKP15 Electric Single Oven
Kenmore Gas wall oven flashes F7 Code
Hi Indy2008,
You can find my solution to the most common cause of the F7 problem at the following link:
I have helped over 1600 folks solve the F7 problem. The problem is usually with the touchpanel and not the ERC. My fix tells how to determine which part is faulty. Hopefully you will not need to purchase a new touchpanel, however, if you do, an internet search will lead you to lower cost sources.
Please let me know if my fix works for you. You can email me at:
Mar 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
Ovens Logo
310 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
