HP Photosmart M415 Digital Camera
Problem for HP Photosmart M415 Digital Camera
Memory added to two computers
By chadrack77 on Feb 13, 2009
I added more memory to 2 computers and now neither one will light up on the screen. The cd rom works and the a drive works, but there is no computer picture on the monitor. Just black. Help!!!
Solution #1
posted on Jul 13, 2009
Not Rated)
johnrray7526
Rank: Guru  HP Expert
Rating: 90%, 405 votes
Sorry to hear about your problems,
1st. We need to know what kind of computer, Laptop or PC.?
2nd. What kind of error messages are you receiving, when the unit try's to startup. ?
3rd. Have you tried to back step and replace the new (not working memory) with the original
Note….. Always have power disconnected from the unit.
Disconnect all devices, lay unit on its side, where you can see comfortably.
Always, double check your work. Take your time.
Chances are, you do not have the memory seated properly.
Look at the memory and try to fit into the bit slot. Do not force the memory.
If you are receiving a Beep message when starting unit, it is not seeing the installed memory.
Install one piece at a time and try powering up unit.
Don’t mix memory, work on one unit at a time.
Hope this information has helped you.
Readers, please rate you technician’s.
Thanks
John Ray
john@johnrraycomputer.com
Was this helpful?
Yes
No
Solution #2
posted on May 18, 2009
Not Rated)
ke3bla
Rank: Guru
Rating: 85%, 10 votes
Remove the new memory and try it again. If it returns to normal then you probably have installed the Memory incorrectly or have a bad stick of RAM.
Was this helpful?
Yes
No
Solution #3
posted on May 13, 2009
Not Rated)
spyke400
Rank: Apprentice
Rating: 100%, 1 votes
Usually this means that the memory is not compatible with the computer you installed it on. Try taking the memory you installed out and put the old memory back in there. Then turn on the computer just to verify that it will load. After it loads successfully (hopefully), Shut down the computer and add one stick of memory to the computer. Turn it on, if it doesn't load then the memory is not compatible and if you have more memory then just keep following the steps above till you've tested all of the memory sticks.
Was this helpful?
Yes
No
Popular Solutions for HP Photosmart M415 Digital
Questions and Unsolved Problems for HP Photosmart M415 Digital
Do you recommend HP Photosmart M415 Digital Camera?
Answer
Answer
can you tell me what memory card to use for the m415
Answer
I can't load images to computer using USB cable. How do I get all of the photo's from my camera on... (More)
Answer
I go to my computer then click on the camera, and then click get pictures and it will not get them
Answer
Lens cover does not always open or close completely.
Answer
Hp photosmart M415 camera. "Error Saving Image" is the message I get when I try to take a... (More)
Describe your Digital Cameras problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Camera Experts
Top Camera & Camcorder Repairmen
in Newport, KY
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
