Question about Husqvarna Chain Saw 20" Bar
Stihl chainsaw How do you replace the fuel line on a Stihl 025 chain saw?
  • Anonymous Mar 26, 2014
    video on replacing stihl 009L fuel line
  • 211 Answers
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Posted on Feb 14, 2009
What other chain can i use on a stihl 025
You need to know three things about your saw as to what chain will interchange....1. Pitch of the chain. 2. Guage of the guide bar. 3. Number of chain links.
Your little 025 Stihl wil probably have an .050 guage and a .325 pitch. The standard guages for small saws are .043, .050 with .058 and .063 being reserved typically for the larger displacement saws.
The pitch is the length of three links, divided by two and the number of links is kinda self-explanatory. (The 025 USUALLY is set up for the .325 pitch.)
Any chain that matches the three measurements for your respective saw should interchange. Hope this helped instead of adding to the confustion......
Sep 18, 2015 | Stihl Garden
Stihl repair manual
You obviously have a fuel problem. Clean carby jets and also check restrictor in fuel line.
Aug 17, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
My saw dies out when I press on the trigger then it picks up after a second or two. What can I look for?
check the air filter and replace fuel filter there cheap should fix it bc its not getting enough of either one
Jul 28, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Saw will start but dies when rev
Check the pick up fuel line in the gas tank. If there is a fuel filter at the end of the line,remove and clean or replace. Use a small fexible wire to hook line and pull out thru gas tank opening.
Mar 14, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Chain oil leaking on 025 stihl chainsaw
Their is a oil passage that has a plastic plug in it by the muffler. It might be gone like mine is.
Nov 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl 025 starts but cuts out have replaced spark plug and new carb
check the spark arrester screen in the muffler. if they stop up it will run like it has
no power and will stall
Oct 29, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Fuel line for Stihl 025 chainsaw
there is a good video on this problem on you tube. should be easy to find.
Dec 20, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
761 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
