Question about Lexmark X4270 All-In-One InkJet Printer
Fax doesn't go thru.
Received fax machine from someone but when I try to send from my phone it just shows the previous persons name in the left hand corner of paper with a black line going thru the middle of the page to the person I'm trying to send it to.
  • sandy390 Feb 17, 2009
    I tried this and it still doesn't work. The person on the other end is getting a black line down the center of the page and nothing else.When they fax me nothing is on the paper. Could it just be no good?
    Still doesn't work...when I send a fax the paper is blank except for a black line going down the whole page. When someone sends me a fax the paper is blank
  • Lexmark Master
  • 684 Answers
Unplug the Power Supply from the printer.......
Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button..........
Now the Printer will ask for the Date Time and Country Language.........
Set everything up......
Now try to use the Printer or try to send a fax it will work Fine...............
Issue Resolved................
Posted on Feb 14, 2009
  • Sanath Kumar V Apr 05, 2009
    Are you Able to Make Copies on the Printer Itself?????
    Are you Using Refilled Catridges?????
Hp 8500 printer/fax machine will no longer receive a fax in color but can send in color. it used to work fine both ways. What can I do to fix the problem?
If the person who is sending the fax cant send in color, then you would not be able to receive the fax in color. Just make sure you choice the option to received the fax in color. Ask someone to send you a fax in color and just received in color.
Feb 17, 2013 | HP 8500 Premier All-In-One InkJet Printer
I can send a fax but when someone tries to send us a fax they show that it's busy (and it isn't).
The fax device requires an expanded capacity phone network structure. For example, phone operated multifunction device get busy when several messaes are being received or sent least aware to the operator. Messages get queued taking several minutes or hours to arrive at machine when transmitted from one place to machine. Allow the fax machine to acquire an aternate network strutcures, high speed, cabels, wireless makes the connectivity acheiveble amongs effectiviness. Consult with an internet structure technician to eveluate the device componenent to determine the requires in cables, expansive devices adn the most effecient mean to attain networking at the area.
Feb 14, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Can't send or receive faxes
it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
Contact your phone service provider to see if they support faxes.
(Faxes cannot handle nearly as much compression as standard voice)
Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
Canon L100 fax receives messages but doesn't print them
Try to clear the fax, with Menu and #, then clear, and select all. Then from begining enter all parameters ( name, number, reports,... ) it should help.
Aug 10, 2009 | Canon FAX-L1000 Plain Paper Laser
WHEN A FAX IS TRYING TO COME THRU, IT RINGS, THEN BEEPS AND SAYS "RECEIVE ERROR"
There may be some static on the phone line, try a line filter. If possible, you could plug the fax into another working telephone line, and have someone send a fax to that number (whatever number is attached to the new phone jack) to isolate whether or not it is the machine, or the wall jack.
May 20, 2009 | Samsung Office Equipment & Supplies
I want my fax's to show my name and phone number
http://www.brother-usa.com/manuals/default.aspx?ProductID=PPF775&ProductGroupID=2&WT.cg_n=Support&WT.cg_s=Manuals
Here is the link for the manual for that machine, you should find the information you are looking for it in there.
Hope this is of some help.
Ed
Apr 19, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Canon 1023if not receiving faxes automatically
Is this fax line shared with the phone? I believe there is a distictive ring setting in the add'l functions area under communication settings then receive settings. you would need to select a ring pattern different so the fax can tell between which types of calls it is receiving.
It has worked for me in serveral other installs
Hope this helps
TankMurdock
Apr 09, 2009 | Canon imageRUNNER 1023iF Black and White...
Given a Brother 590MC FAX machine, Need to remove previous detail
You can go under (menu) and then (Initial Setup) and using up or down tabs move till you see Machine ID. Press (menu) or (ok) button and change phone, fax number, and name. Press(ok) button after each is set to your specification. Hope this helped!
Mar 13, 2009 | Office Equipment & Supplies
I have an HP Officejet v series printer, fax, amd copier. It will send a fax, but it is not received. Someone can send me a faz, it sends, but I don't receive it.
Verify that the sender has the correct fax number.
Call your fax machine from a regular phone and listen for fax tones.
Fax machines are ANALOG devices. Make sure your fax machine is not connected to DSL or any other digital phone line.
Sep 30, 2008 | Office Equipment & Supplies
FAXING
right click on the for the printer, Left click on 4200 ALL IN ON CENTER (top). Look at the top right hand corner and you will see FAX UTILITY, go thru those steps. Email me if you are still having problems. burpo01@aol.com
May 07, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
