Question about Sony BRAVIA KDL-40V2000 40 in. LCD Television
Cannot get sound
Have sony bravia tv cannot get sound. Is there something that could be tuned off? no external speakers in use
  • 1 more comment
  • wybos1 Feb 13, 2009
    volume is not muted sound can be turned all the way up but no sound
    tried all solutions. still no sound. everything is turned on.....no sound.
  • wybos1 Feb 14, 2009
    no pins are bent everything seems to be pluged in as usual.
  • Sony Master
  • 19,396 Answers
Try first replacing the cables (if you use RCA replace audio cable, if HDMI test different cable).
If this is not a cable or setting problem , than it is an internal fault, probably a faulty audio circuit inside the TV.
In this case contact the number listed on the user manual or a local repair shop to get the unit fixed.
Posted on Feb 15, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Pls disable SAP, in sound setup/selection, choose either MONO or STREO.
Good luck and thank you for using FixYa.
Posted on Feb 14, 2009
  • 10,515 Answers
2 solutions :)
Actually there's one setting, I'm not sure that you have try this or not. It's under set up menu (not sound setting menu) check speaker setting (it's must be On). If this one already ON but still no sound, please contact service center.
or
It depends of the type of cable you have. If it is just regular cable connet the coaxial cable to you tv and the sound is carried with it. If it is digital from a settop box you'll need to hook up sound form the settop box. You can use the L and R RCA cable or the digital coaxial cable if you have go a 5.1 channel reciver. If it is HDTV settop box, its the same story as for digital. Do you get sound with you dvd player, then your tv is not the problem and its just you not knowing how to connect the cables. For starter, I would reccomend that you connect the R and L audio from your settop box to your tv. Remember to connect the video and the audio to the correct input and put the tv in the correct input by using the remote.
  • 142 Answers
Actually there's one setting, I'm not sure that you have tried this or not. It's under the set up menu (not sound setting menu) check speaker setting (it's must be On). If this one is already ON but still no sound, please contact service center. This should do the trick though.
Please remember to rate this fix.
  • 217 Answers
Is the problem present all the time even when watching the cable tv
  • 1 more comment
  • Saroj Sharma
    Saroj Sharma Feb 14, 2009
    Check the following link for proper setup
    http://support.sony-europe.com/tv/tutori...
    and for troubleshooting :
    http://support.sony-europe.com/tv/lcd/lc...
  • Saroj Sharma
    ❑ Set Speaker to On in the Setup settings. If it is set to Off, sound is
    not output from the TV’s speakers regardless of the TV’s volume control.
  • Saroj Sharma
    Also download the manual from the following link for more info:
    President:
  • 2,559 Answers
Go to the setup menu,scroll down to Speaker,Make sure it is turned on.
If it is turned on,check an external speaker via audio output jack.
If no sound from audio output jack either,The the sound board is bad.
Also if you would like more info,You can get the manual here This is a direct link to the pdf file.
Posted on Feb 13, 2009
  • 565 Answers
If your media is encoded with sound formats that are not recognized by your player or AV receiver, this may result in no sound at all. Make sure that your hardware devices are compatible with the sound format you want to playback.
  • 33 Answers
Hello Wybos1,
There are many reasons why sound would not be present on your HDTV. One is if you are using and HDMI cable for the picture and other connections for the sound. HDMI cables are able to transfer both the picture and the sound through one handy cable, but sadly some receivers that are out dated are unable to send the sound through that cable and require audio cables.
Recievers that use a DMI connection with an adapter of sorts, are the ones I am talking about.
Though the audio cables plus a HDMI work on some TVs, yours is not one of them.
Your TV requires either the use of just HDMI with out audio coming in from another jack, or the use of all jacks without HDMI.
Do not think your TV is bad, because most likley if you are using your HDMI, it will be your reciever that is the issue.
Now if you are using a direct coaxial cable (Just regular TV cable) There is a problem with the TV itself.
I hope that I have helped you with your issue today, and please take the time to rate my solution. If you have any questions feel free to post them before rating my solution so that I may give you the most assistance I can.
Shadowmaru.
  • 6,784 Answers
Hi, make sure that the speaker options are set to internal speaker system and not external amp.
  • Michael Masters
    Michael Masters Feb 13, 2009
    You will have to go into the speaker menu and set it to on. and, remove any head phones if they are connected to the set.
  • Michael Masters
    This option is in your set up settings. turn the speakers on
    Brigadier General:
  • 8,619 Answers
Hi!
Are you using a DAO(digital audio out cable)? Also try and tune your TV on a diffrent video channel. If using HDMI, please check for the pins of the HDMI connector, are they bent or broken?
Please ask for any clarifications
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Feb 14, 2009
    If all cables are fine and settings are also perfect then check for loose connections on the circuit board and also with the speakers. But, before doing that plug in external speakers and see if sound is coming from them, if yes then internal speakers are bad and if no sound from external speakers aswell then the sound circuitry has gone bad.
  • 11,896 Answers
You should have a setting in the menu for sound options, make sure the tv speakers "on" is checked/highlighted. If you have all settings and cables set correctly your tv should have sound. If you still do not have sound then there might be a problem with the sound card outputs on the television.
  • Nate Stansfield
    Nate Stansfield Feb 26, 2009
    go to menu, sound settings, find or look to see if you have a "speakers on" setting and select it. If not there may be bad or loose speaker wire or worst case senario is the sound board fried. But first, do what I very first suggested.
  • Sony Master
  • 13,433 Answers
The volume could be low or muted. check by using the remote. Also check the cables behind the tv and that sound cables or cable is connected properly, check the menu and make sure sound is not muted and corrent source is in use.
  • Ekse Feb 13, 2009
    is the sound source outside the tv? I mean can you move the device to another tv to test if you get sound out from it.
    if you get sound from the source at another tv, assuming its a external dvd player for example. the problem is on your tv, as you have no sound at all, does this include all sources? The speakers may not be functioning.
    if you don't get sound from the device at another tv then the issue might be on the device and not on your tv, try another device on the tv and see if you get sound.
    I suppose the internal tuner is not giving any sound either?
  • Ekse Feb 14, 2009
    got headphones? try them on it?
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
I have a sony bravia KDL-32L4000 LCD TV and the sound has gone
For anything you plug in or just certain things? Before the sound stopped, did you change the sound output to something different? Do you have external speakers plugged in?
If the built-in speakers on the tv are not working, plug the television into a set of external speakers, select the output in the menu accordingly and test them. If they work, might be the speakers are blown or the menu configuration is wrong.
Always check the simplest things first, then work your way up to the harder/more expensive issues.
Rule out speakers, speaker board, connectors, external speakers, components attached to television, etc.
Mar 07, 2013 | Televison & Video
No sound from the audio speakers
by audio speakers i assume you mean speakers that you plug INTO the tv, some tv's if you plug in speakers they play instantly but some tv's you might have to go under the menu ON the tv so just bring up menu, click on audio, and it should say some where to swith to external speakers then while with speakers pluged in select external speaker (or whatever your tv might say) and i hope that solves your problem, thank you, jamie.
Dec 15, 2012 | Sony BRAVIA KDL-46EX720 46" 3D LED-LCD TV...
My sound bar hooked up directly to my tv has no sound
You may have to go into the Bravia setup procedure and opt to disable its internal speakers
Nov 17, 2012 | Boston Acoustics TVEEM25 TVee Model 25...
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
How do i hook external speakers to sony bravia television
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Aug 21, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
Feb 08, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sound problem
check the menu on the tv to see if the speakers are set to off
I think if you connect it to external amp the tv's speakers must be shut off beofre it will activate the line out audio
Nov 05, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL-40V2000 40 in. LCD Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
