Question about LG E500 Express Dual Series Notebook PC
WIRELESS NOT WORKING - LG E500 Express Dual Series Notebook PC
  • 1 more comment
  • malcolmcarey Feb 23, 2009
    Im running windows vista home. the wireless signal light has two modes. when the wireless button is pressed it used to light up light blue and then dark blue if pressed again. now when I turn my laptop on the wireless light stays green! i can't figure this one out. HELP!
  • Greg Caudle May 11, 2010
    How long have you had the unit?
    What is type of OS, XP Pro, Home?
    Has it worked for you in the past? If so, what software or hardware had changed?
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there
    We need more information please
Wireless router woks if wired won't work wireless
Wireless router works if wired won't work wireless
Sep 21, 2012 | Linksys Wireless-G Broadband Router
Will any Wireless Adapters work without the PC's NIC?
Yes even without any NIC card installed on your computer , the wireless adapter will definitely work since its a different device that work for wireless connection and has nothing to do with your NIC card configuration.
May 15, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
I have a wireless G Plus MIMO router that isn't working right.
The wireless router needs the wireless settings configured eg. the SSID, encryption etc and then the wireless card in the computer/laptop needs to be configured with the router's wireless settings. Please click on this link and follow my instructions to secure your wireless network :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 07, 2010 | Belkin (F5D5231-4) Router
I have a d-link router. i can connect to my
The wireless card is configured for your D-Link at home.
You need to configure your laptop's wireless card for the wireless settings at work too (ie the SSID and encryption etc.). Contact the network manager at your work for the wireless configuration so you can configure the wireless card with these settings.
It maybe possible to setup different profiles on the laptop's wireless card, one for home and one for work so you can just click on the correct profile depending on your home or work location.
Dec 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
My wireless on my f5d7230-4 won't work but when i hook up a ethernet cable from the wireless router to my laptop the internet works but my wireless will not work
With the ethernet cable , it is working, Ok the router wired part is working but the wireless part is not working.
on your laptop , does it say connected to your wireless network ?
If it is not then try to connect to the wireless network .
Make sure that you have the correct wireless settings of the router .
Click Here for step by step solutions
Nov 12, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless router not working wirelessly
First of all,check the DHCP option in wireless router.If its enable then go to remote user whether PC or laptop enable the DHCP option.
Defaultly laptop have wireless adapter.But IN system doesnot have.SO you need to buy a new wireless adapter..
Oct 05, 2009 | D-Link DI 514 Wireless Router (DI-514)
I own a HP DV9000 my wireless quit working
Check the Device Manager to see if the Wireless LAN device is working and enabled. If not reinstall the Wireless LAN driver.
If the Wireless LAN is OK and enabled then sometimes when you bootup the Wireless LAN card doesn't get an IP address from the wireless router. This usually has a red X on the wireless connection icon and sometime you get an error message "Limited or no connection".
To get the router to issue the wireless LAN card with a new IP address, righr click on the Wireless icon and click on Repair.
You can also power down the router wait 15secs and power up the router again then reboot the computer.
If it still doesn't work you could have a faulty wireless card, see it your friendly computer shop can test it for you.
Jun 30, 2009 | HP Pavilion dv9000z Notebook
Internet setup
few things you can try:
1. check to make sure you're getting an IP address.
2. try reloading the wireless card driver.
3. is you wireless static or dynamic? If dynamic, try configuring it with static setting.
4. If this don't work, try the wireless card on a different slot.
5. if don't work, try on a different PC to see if wireless card is working or not.
It's possible you have a bad wireless card.
good luck!!
Mar 31, 2009 | Dell Dimension 8400 PC Desktop
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
LG E500 Express Dual Series Notebook PC Logo
141 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
