Question about Kenmore 15864/15862 Top Load Washer
How do I find model number?washer just hums
The model # I found is mau6257aww
washer fills just hums,looks like it wants to work,clicks,hums,and smells like its getting hot
    President:
  • 1,902 Answers
Check the motor or the tub bearing. Something is frozen on your machine and not letting it spin. You can also check the brake or clutch and make sure it is not stuck. On the back of the unit when you remove the back panel you will be able to see everything that you need to get at
Posted on Feb 13, 2009
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Stagnent water smell while filling
I found that running about a quart of white vinegar through a cycle with hot water and no clothes or detergent takes care of the musty smell. Vinegar removes detergent build-up.
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer filled w water but wont agitate,spin or drain. I hear a humming,buzzing and something smells like it is burning. After several attempts to start in various different cyles it may have tripped...
send the model number.if it's humming it sounds like the motor is bad.where.if it resets after a while and hums again it's the motor.there's an overload in the motor,when it gets to hot it pops and will reset after it cools.
Apr 13, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
The washer hums and blows the breaker
It sounds like a motor problem to me. The transmission in not elecrtical but it could be locked up. Try turning the tub by hand and see if it turns. if not take the motor out (unplug first) and try to turn the transmission. But with the "hot smell" more and likely the motor is shot. This is all depending on your type and modle of machine you have. Let me know.
Apr 06, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer stops at rinse cycle-hums and has a smell.
Problem is with your lid switch which has to be replaced. This is if your filter is all clean.
Feb 28, 2009 | Kenmore 15864/15862 Top Load Washer
Burning smell and washer will not spin
The buring smell could be coming from the belt, try looking to see if the belt i burnt or broken
Nov 22, 2008 | Whirlpool LSN1000LW Top Load Washer
Washer won't fill with hot water
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
Oct 26, 2008 | GE WBSE2090A Top Load Washer
Washer will not fill with water.
YOUR INLET WATER VALVE ON THE BACK OF WASHER HAS FAILED,HAVE YOU TRYED IT ON COLD ONLY,HOT ONLY TO SEE IF ONE OF THE VALVES WORK?IF NOT YOU CAN GO TO SEARS .COM CLICK ON PARTS PUT IN YOUR MODEL NUMBER AND YOU CAN ORDER THE PART YOU NEED,LET ME KNOW HOW YOU DO-MIKE
Aug 02, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 15864/15862 Top Load Washer Logo
62 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
