Question about Panasonic KX-T7130 Corded Phone
Call Out line is lost
I have Panasonic KX T7433 with 4 call out lines.  I was trying to reprogram but lost one off the call out lines. I downloaded a manual but that has no help on how to get back the call out line
  • yousuf934 Feb 20, 2009
    Thank you Carl. That fixed the problem
  • Panasonic Master
  • 2,460 Answers
If you truly have a TD-816/1232 system consistent with the 74xx series phones, and not the 7130 you posted under, you need to find out what line you lost, or how another phone is programmed.
Go to a working phone, press PROGRAM 99 and the buttons on the key strip. They should say CO-001, 002, 003 etc. Now go to the non-working phone and do the same thing. A C.O. is programmed by the code 0 + the 2 or 3 digit trunk number, so you press the missing line button and dial 0-(0)01 STORE or 0-(0)04 STORE, depending on which end you lost it from.
Pick up the handset and hang it back up to exit programming.
Carl
Posted on Feb 13, 2009
Phone line went down need to reprogram voice, transfer button for panasonic KX-T7420 DIGITAL PHONE
Program 99 press the button and dial 8 165 STORE. That assumes that you're using the default VM access code.
Carl
Feb 09, 2011 | Panasonic KX-T7420 Corded Phone
I have 2 Panasonic wireless phones ModelKX-T7885 and a panasonic PBX. One wireless phone will not display F1 thruF4 lines; it displays F9 thru F 12 only depspite reprogramming the unit to default settings....
Hello, Peter.
Try resetting your modem / router that provides the connectivity.
Then, if necessary, re-power (Off and leave for 10 minutes, then On) your phones.
Hope this helps.
Sep 15, 2010 | Panasonic KX-T7885 Cordless Phone
I'm using Panasonic KX-T7730 and I'm having a problem because i can't assign my other line.. the display show CO not assigned.. what will i do with it?
This is a physicians office and in the past we had to dial nine to get and outside line. Recently we updated to where we have to dial one and then the area code. However since the change our answering service can not get calls after hours because i believe our phones are still programmed to dial nine first. Can you please help us reprogram our phones? Thank you.
May 25, 2009 | Panasonic KX-T7730 Corded Phone
I want to Reprogram a KX T7730 phone to allow outside lines
Doorphone ringing is programmed in 607 and 608.
With luck, flip the manual back a couple of pages and hope that the extensions are restricted via outgoing line access in 605 and 606. It's the easiest way, but there may be some COS restrictions taken care of in 601.
Carl
Apr 08, 2009 | Panasonic KX-T7730 Corded Phone
Dead handsets
i had the same problem with my KX-TGA650 and called repair out and they said it wasn't seating on the home base to charge, we'll see. i'm looking for a manual for this phone lost mine and cost prohibitive to order from panasonic. and download pdf is just too large.
go to website and it tells you that only a same model is able to be used with the base unit. hope this helps.
martha
angelml@sbcglobal.net
Jan 05, 2009 | Panasonic KX-TGA650 Cordless Expansion...
Line program in trouble
Here is a link to the instructions in case you don't have them
http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
have a look at page 2, also the section on "clearing all settings"
Jan 17, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7130 Corded Phone Logo
201 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
