Question about Fujitsu AMILO PC Laptops
AMILO pro v2055 Shuts down not long after starting up
When I start up my AMILO pro v2055, It works ok for a few mins then it goes to a blue error screen, cant remember the message. Can any one help at all. Has a fresh install of Win Xp.
  • mplsiv Feb 13, 2009
    Hi checked the ram. Its not the ram as when it does turn on and work for a few mins, it works fine. Thank you
    Sergeant:
    Champion:
  • 237 Answers
Sounds like it could be a ram issue. Rule of thumb for blue screenis to check the ram first
Posted on Feb 13, 2009
  • John Cole
    John Cole Feb 13, 2009
    Have you checked the cooling making sure the cpu isnt overheating?
Fujitsu amilo pro v2055
Press and hold down the "fn" key - bottom left next to "ctrl" key - and press brightness key at the same time.
Aug 14, 2014 | Computers & Internet
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
Key replacement
whole keyboard is replaced as a unit. Cost about $21 for the part.
Sep 25, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Amilo Pro V2055 Wont start up
Try reseating the memory and the hard drive if you can remove it easy enough, if this doesn't work you may need to take it to your local computer repair shop.
Good Luck.
Feb 18, 2009 | Fujitsu AMILO PC Laptops
AMILO pro v2055 Restarts randomly when in use
this sound very much to me like overheating check all the vents on the laptop make sure they are free and clear. If you have used the laptop on a bed or sofa for a period of time the vents can become clogged with a buildup of dust, if this is the case then you will need to open up the laptop and clean the fan and heatsink. you could also try vacuming the vents.
techbug
Feb 15, 2009 | Fujitsu AMILO PC Laptops
AMILO pro v2055 wont even turn on now
Try reseating the memory, if that doesn't work, you will need to take it to your local computer repair shop.
Good Luck.
Feb 14, 2009 | Fujitsu AMILO PC Laptops
Amilo pro v2055 blank screen
Remove the battery and the power supply. Hook it to wall power only w/o the battery and try to turn it on. If it boots great, otherwise pull the power from the unit while it tries to turn on. Plug it back in and try turning it on again. If that doesn't work you need to re-seat the RAM and/or processor. Last thing to try if that doesn't work is new RAM as a processor almost NEVER goes bad and it is either the RAM or the motherboard at that point.
Nov 10, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens Amilo Pro V2055 laptop power on problem
Check to see if the ram is securely in place. (that will cause a pc to not boot, usually there is a beep code tho)
Oct 06, 2008 | Computers & Internet
Amilo xa series
The fan speed is controlled by the processor and BIOS. It is on full speed when it starts, but the processor turns it down again as soon as it starts to run.
Could be loose memory modules or the processor heatsink has come loose. Try taking off the back compartments and check everything is fitted OK.
Jul 27, 2008 | Fujitsu Siemens AMILO Pro V7010 Notebook
Amilo Pro v2055 Sound very quiet
Go to control panel then sound and audio devices then speaker volume and see what level it is set on.
Nov 01, 2007 | Fujitsu AMILO Pro V1000 Notebook
Fujitsu AMILO PC Laptops Logo
331 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
