Question about Hotpoint WMA64 Front Load Washer
Hotpoint Door Seal WMA64
We have bought a new door seal for our Hotpoint WMA64 washing machine. Could you tell us how we go about changing the door seal?
    President:
  • 842 Answers
I have reproduced the details of my article: http://www.fixya.com/support/t1543617-door_seal
here. I hope this will give you the information you need.
Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until it is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
Posted on Feb 15, 2009
How do I replace the front door rubber gasket and seal ring?
Greg, new seal but need to know how to swap it out. Check the attached links,instruction and guides, If you want to google your make and model Washing Machine door seal replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Replace Washing Machine Door Seal
How to replace washing machine door seal on Hotpoint washer
http://www.how-to-repair.com/help/how-to-replace-whirlpool-washing-machine-door-seal
How To Replace Front Load Washer Door Boot DIY
Jul 25, 2016 | Washing Machines
Fit a new door on a washing machine
You need to remove the wire clamp that holds the door seal on to the front of the cabinet, then pull seal off.
This will give you access to the door hinge assy, then you can replace the door complete.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint Washing Machines
How do I change the door seal on my Hotpoint WMA40 washing machine?
It's a push fit seal. Carefully remove the old one and for help, smear the new seal where it fits the machine and just push it into place securely.
Sep 07, 2009 | Hotpoint WMA40 Front Load Washer
Changing door seal on hotpoint ultima washing machine
hello if you take the top off the washer and look down inside you should see a metal ring with long screw and nut unscrew this so it's loose you should be able to pull the seal off .then on the front of the washer where the next part of the seal is theres another rmetal thin bit of wire . unscrew the platic clip and the wire should come off. then just pull the seal out of the washer and when you put the new seal on fit it the same way you took it off good luck ps get back to me if you get stuck
shaun
Sep 06, 2009 | Hotpoint Ultima WF860 Front Load Washer
DI 'My self' Washing Machine Door Rubber
This video will show you how to change the door seal gasket on your neff washing machine Neff W5340X0
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Neff W5340X0 Washer
Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Nov 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wma46 door lock
make sure door seal is fitted correctly to the cabinet. you may find that all that is required is to push the door harder than usual till the seal beds in
Mar 29, 2008 | Hotpoint WMA46 Front Load Washer
Door seal
i will tell u step by step 1)open the door undo the clamp that holds the front of the seal on it is around the lip push door seal back so its out of your way into the drum 2)take the lid of look to the front were your seal is fastened onto the outer drum this is held into place with a screw clamp unscrew it and u should be able to ease the door seal of from around the drum reverse these actions to replace the new 1 i have sent these instructions too 3 other people they have found these instructions easy to follow and do
Jun 24, 2006 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
248 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
