Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
Need to know where all the front connectors go
I removed them to clean my computer and i put everything back where it was and it still wont boot up. i am 99% the front connectors is the problem can anyone tell me how to connect them correctly?
  • 2 more comments
  • ryan christie Feb 13, 2009
    umm the connnectors that turn on and reset your computer u know the red white blue white yellow white green white
    hmm this is very helpful BUT i need to know are the colourd wires + or -
    dunno the powerbox must be shot cause its makin funny noises so i'm just gonna try another one i guess and if it doesnt work then i dont know... thx alot for that manual i appreciate it
  • Juanita Vega
    Juanita Vega May 11, 2010
    you have to explain a little more
  • 45 Answers
For the switches, polarity really doesn't matter. It seems that the biggest thing for you is the LEDs. General rule: if it doesn't light up, or lights the wrong color, reverse the polarity.
Posted on Feb 13, 2009
    Scholar:
  • 75 Answers
Well mate every connection that you wanna make you'll fin it in the manual... here is the direct link to download the manual.. it is completely illustrated n is a breeze to set up
http://download.gigabyte.ru/manual/motherboard_manual_8vm533m-rz_e.pdf
Lemme know if this solves anything...
  • ashish13
    ashish13 Feb 13, 2009
    Page 15 of the manual mate... each pin is explained
SOURCE:
Stuck sleep mode
The solution to no post on a computer is to remove everything that you can, take out the hdd, the ram, and optical disk and see if it boots. If it does, put the RAM back, then try again, if it does, put the hdd back and try again. It is a process of elimination. If everything is removed and it wont boot, it may be the motherboard. I have also seen bad batteries do this. There is a chip inside the battery that wont let the machine boot when the life of the battery is expired.
Aug 19, 2017 | Toshiba Computers & Internet
My T2300 wont boot up,I was trying to take a memory card out of the slot and the AC power outlet came out and the laptop came off. Now it wont boot up
Try removing the battery from the base. There is a sliding switch that will unlock it for easy removal.
make sure there is no power coming to the laptop.
Press and hold the power button for 5 seconds.*This should drain static from the motherboard
plug JUST the power cord back in.*To prevent any battery issues messing everything up
Press the power button.
If it boots you can put the battery back in.
* On my posts, i will try to explain what everything does for people who want to know
Oct 12, 2010 | MPC Computers TransPort T2300 Notebook
I unplug my front audio connector cable and usb 2.0 connectors on my motherboard while putting in a new graphics card in the pci-e slot. After I inserted them back, my pc didn't want to switch on and I...
Uninstall the newly installed Graphics card and boot again. If it boots up normally, then the graphics card must be incompatible with your motherboard or might have some defect with it. Or if the system doesn't boot up even after the new graphics card is uninstalled, then you need to recheck the connectors and make sure everything is connected/inserted properly and fitted. The best way to check connection faulty is, plug-in one after another while you boot the system everytime... you plug in a connector. First connect the power switch and so on..
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Oct 08, 2010 | Biostar MCP6P-M2+ Socket AM2+ GeForce 6150...
How do you change the front brake pads
Too easy. Pull the wheels off. on the back side of the calipers you will see two small rubber boots top and bottom. inside are 7mm or 1/4 inch allens. once you screw them out you will have to remove the clip across the front to release everything. once off remove the old pads. collapse the caliper, replace the new pads and put everything back togather. My pads came with a connector but my vehicle did not have a place for it to plug in so i cut them....which were the same as the old ones on the car.
Mar 08, 2010 | 1996 Audi A4
I have an f28 failure code on my Kenmore HE2, I have run diagnostics and everything seems to run okay. I have checked all the connections and cleaned out the pump filter. It seems to be when the pump is...
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$
Mar 07, 2010 | Kenmore HE2 Plus Front Load Washer
Wont play dvd or cd
Does this happen to all cds? If yes, your DVD/CDrom might need cleaning. Try cleaning it using a cd cleaner and let it spin for 30 seconds. If it still does not read cds, you can open the casing and clean the lens with a soft earbud damped in an alcohol and gently wipe on the lens. Put everything back and try playing cds again. Also, make sure that your cds are clean so that the lens wont be having hard time reading them.
Hope this helps. Goodluck!
Oct 01, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
Need2 know wiring diagram 4 power supply 4 a emachine T2642
Hi there
The power supply should be ATX 20pin connection and also a 4pin connector, look at this picture below so you know you have the power connections in the right places>>ba37bd3.jpg
On the top left of the picture, the big cream 20pin socket is where the 20 pin connector goes.
In the middle to the left you will see another cream 4pin socket is where the 4pin connector goes.
If your power supply does not have the 4pin connector the pc won't boot up, you will have to go out and buy one.
If you have all the connections right and the on/off button is connected to the front panel properly, take out the system memory, clean it with a clean, dry, soft pain brush and also clean the slots too, re-seat the memory and reboot the machine to see if it boots up.
Good luck and thanks for using Fixya!!!
Feb 19, 2009 | E-Machines eMachines Desktop PC
Processor
Open the case and make sure all the connectors are attached and where they should be.
Robert
Aug 31, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
No Boot on 1600sc
The easy answer is: Did you ensure the CPU fan connector is attached to the PROPER motherboard CPU fan power pins? The 2nd easy answer is: Are you sure your CPU is properly placed inside the socket? Could it be tilted slightly up on one side? The more complicated 3rd answer is: I've seen people use the spray can of AIR, which, believe it or not causes a moisture problem AND can overly cool a component. Although the motherboard looks fine, it won't boot or power on until the part(s) rewarm to room temperature or the moisture dissipates. This is how I solve this problem. I remove the motherboard or open it completely up to clean it with 80psi of compressed air. (remove all components) If it had previously been cleaned with a can of AIR, I let it sit for half an hour. When putting the parts back together (leave the HD, the CD, the floppy disconnected), (oh...ensure your front panel connectors are properly on the correct motherboard pins too.) 1)take extra caution with both the video card and the memory chip slots!! Inspect the video card gold edge and video card slot for a few strands of carpet fiber or DUST bunnies wedged or attached to the card/slot (which causes the computer to not power ON) 2) Inspect the memory sticks and memory slots in the same manner. (I had to see it with a magnifying glass, to see the problem) Once back together, if it boots, I'm done. If it didn't boot, I replace the power supply. If that didn't solve it, I reposition or change the RAM memory. Attention to detail is the key to success. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Dell PowerEdge 1600SC Server
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
91 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Ekse
Thomas F. Schneider
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
