Question about Microsoft Xbox 360 Console
Xbox360 wil turn on if i press button, wont recognize controller
My xbox360 will not turn on with controller, will turn on if i press the button on the console, but atill will not recognize the controller.
  • 2 more comments
  • gpsfan Feb 14, 2009
    Mine will turn on with either the controler or the power switch on the console but will not recognize the controller...ie. the light flash continuously on the controller. If I hold the power button on the controller, it does turn both controller and console off.
    The light on the power brick is green.
    There is no picture on the tv.
    Have tried multiple controllers including the guitar and drums from Rockband2.
    All controllers will connect to a different console without problems.
    The console is the Xbox 360 Arcade console, owned less than one month.
    Have replaced all batteries.
  • juan_ka2000 Feb 14, 2009
    when i turn on the console no lights come on but the system loads and games start playing, but does not recognize controllers... ive tried re-syncing and changing batteries to no avail
  • james morgan
    james morgan May 11, 2010
    its probably something youve done but can you take out the batteries on the pad and replace them, re-do the alignment on the pad and console then try again to see if that helps
    www.fixmyconsole.co.uk
  • Erin Picton May 11, 2010
    When you press the button to turn on the controller, do any lights come on at all?
    Novelist:
  • 174 Answers
Its possible the ir board what could be faulty, your best best is to try and get one from ebay or on the net and replace it and see if that cures the problem. to remove the ir board simply take off the case then get a t8 screwdriver and on the front of the console clip off the small plastic cover and there is 3 screws holding this to the casing. remove them and pull off the ir board and replace it. put the console back together then try it again
hope this helps
Posted on Feb 15, 2009
How do you set up a wireless controller toxbox 360
You can do so by turning both Xbox 360 and your controller on then looking at the front of your Xbox 360 for a button Other than the Power button. Press that button and you will see your console light start blinking. Turn your Xbox controller facing up and you should see another small button with waves like this (((. press the button so the xbox360 can find your controller
Aug 08, 2015 | Video Game Consoles & Games
How to reset xbox360 dashboard
To reset Xbox 360 console display settings
If there is a disc in the console, remove it.
  1. Turn off the console.
  2. Turn on the console by using your controller. To do this, press and hold the controller's Xbox Guide button until your console turns on.
    Note If multiple controllers are connected to your console, make sure that you use the player one controller. You can recognize the player one controller because the upper-left quadrant of the Guide button is lit up on that controller.
  3. While the console is starting, press and hold the Y button and pull the right trigger at the same time. Continue holding the buttons when you see the Xbox 360 logo.
    The console will restart and you will see the Xbox 360 logo again.
    The console's display settings are now reset to the defaults.
Sep 22, 2011 | Microsoft Xbox 360 Console
Well my controller wont start up my xbox360 i took the hard drive to a friends house and a controller for a day than when i got back i got back on my 360 and it wont start up ?
press the button on the top of the wireless controller while its on and turn on your xbox. then press the button directly next to the power button
Feb 24, 2010 | Microsoft Xbox 360 Wireless Controller
When i turn on my xbox360 controller all 4 rings light up on the control but doesn't connect
You need to press the sync button on the Xbox360(little white button on the faceplate just under the DVD drive). Then you press the sync button on the wireless remote. (An even smaller little white button, on the side of the contoller that would be "facing" the 360 while you hold the controller)
Nov 24, 2009 | Microsoft Xbox 360 Controller
Wireless controller flashing green light but wont detect xbox360?
Have you tried resyncing your xbox and controllers? On the controller, press the little circle button on the top of the controller, between the bumpers. On the 360, there's a small circle button, about half inch wide, next to the memory card ports. Press that as well.
Jan 05, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't recognize my controller!
Turn on the X-Box, turn on the controller, press the "Find" button on the X-Box, It's the 3/8" ROUND button on the consol. Press the find button on the controller. It's the 1/8" round button next to the LB button.
Dec 29, 2008 | Video Game Consoles & Games
My new hand control just flashs green all the time
When you tried to use the new controller did you sinc it with the Xbox? There is a very small button on the front of the controller at the center. You need to turn the XBox360 on, then your controller and press the small button at the center front. Your next step is to press the small button on the XBox360 console located to the left of the power button. Both the controller and XBox360 should start to flash until they sinc up.
Dec 09, 2008 | Microsoft Xbox 360™ Premium White Console
Xbox360 wireless controller not being detected
1. Turn XBOX360 on
2. Press the sync on the XBOX360, green lights swirl
3. Hold the center xbox logo button on the controller, lights swirl
4. Release the xbox logo button on the controller then press the sync on the controller
Good luck
Dec 04, 2008 | Microsoft Xbox 360 Console
Wireless controller position
Try this:
Under heading "How can I change the screen positions for my wireless controllers?"
http://www.xbox.com/en-US/support/systemuse/xbox360/resources/supportfaq.htm
To reset the screen configuration for an Xbox 360 Wireless Controller:
  1. Turn off your Xbox 360 console and any connected Xbox 360 wireless controllers.
    (To turn off your wireless controller, power down the system and wait for the lights around the controller's Xbox Guide button to disappear.)
  2. Manually turn on your Xbox 360—don't use your controller's Xbox Guide button.
  3. Press the connect button on the front of your console. This is the small button just to the right of (or below, if your console is on its side) the port for Memory Unit B. The lights around the console's power button will flash as the console searches for a wireless controller.
  4. Press and hold the Xbox Guide button to turn on the wireless controller that you want to assign to slot one.
  5. Once the controller is on and the lights are still circling the power button on the console, press your controller's connect button, located just to the right of the charge port.
    When the lights on your controller stop spinning, the wireless controller is configured to slot one and the upper-left quadrant light will glow.
  6. Select the controller you want in slot two and repeat steps 4 and 5. You can configure up to four wireless controllers.
Sep 01, 2008 | Microsoft Xbox 360 Controller
My philips gogear 8gb won't come on.
you wil need to get windows media player 11 and update your usb drivers
Mar 26, 2008 | Audio Players & Recorders
Microsoft Xbox 360 Console Logo
397 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
