Question about Whirlpool Washing Machines
Simpson 175 wont take on hot water
I have a Simpson 175 washing machine that works fine but it will only take in cold water,The hot water will not go in the machine.
    President:
  • 1,902 Answers
Your water inlet valve is bad on the hot water side and needs to be replaced. It is located right after the supply hose for the hot line behind the back plate
Posted on Feb 14, 2009
Hello, My old simpson 175 goes fine upto the spray rinse and then makes this HORRIFIC screaming sound! As its so loud, I dont know if it is actually working but you HAVE to stop it. It sounds like...
Yes sounds like a dry bearing. Belt driven machines can also make a screeching noise if the belt slips. Spray with Belt Conditioner available from auto supply shops. Australian machines a bit problematic for this North American based site. I see manuals listed but nothing that looks like a schematic or workshop manual. There is a link to the Simpson website though.
https://www.simpson.com.au/other/contact-us/
[PDF]User Manual - Simpson https://www.simpson.com.au/globalassets/...manuals/sman_ezisensor_feb12_omo.pdf
  1. Cached
SWT801 and SWT951 Control Panel. Important Safety Instructions ii. 1. Water Saving Technology. 3. Knowing Your Washing Machine. 3. Washing Intructions. 4.
simpson 175 washing machine schematic Google Search
Aug 27, 2017 | Simpson Washing Machines
Setting our machine on warm , but the water s hot , both hot & cold taps are fully turned on .
Check your hot/cold inlet valve and solenoid. It sounds like your cold water side of the valve is stuck shut. The valve is found by following the inlet hose right to it. Also, do you have a domestic well as water supply? Sometimes fine sand from a domestic well will plug the valve screen. It is also possible that other mineral would plug the screen. These things would happen gradually, though, not all at once.
Feb 02, 2017 | Simpson Washing Machines
Hey I have a simpson swt802 and the on the temperaturebutton the hot,warm,and cold buttons flash and beep and I don't know why now the machine wont start..please help
Read your operating owners manual or if you don't have one then do a Google search for "Simpson SWT802 operating manual" The number of beeps and flashes tell you which fault it is.
Nov 06, 2016 | Simpson Washing Machines
My simpson eziset 750 is leaving grease marks on clothes after wash. Whats wrong?
Do you use fabric softener? Too much softener & too many cold water washes results in a build up of black soap residue on the outside of the inner bowl. You could try a hot wash with some white vinegar in the water (No clothes just the water) If that doesn;t work then you will need a service person to come & take the bowl out for cleaning.
Jan 02, 2016 | Simpson Washing Machines
My washing machine goes fine until half way through wash then comes up with error code PU and beeps until I turn it off...will not drain out the water? Simpson encore 556
simpson encore pu Unsolved Problems - Fixya
www.fixya.com/unsolved_problems/simpson_encore_pu
Unsolved problems for simpson encore pu question. Get free help ... My simpson encore 757 shows PU error code. What is this? ... Simpson encore 556. Aug 22 ...
Sep 10, 2015 | Simpson Washing Machines
Simpson 175 shorting out
there are 2 items that come into play when the wash cycle starts 1 is a capacitor for the motor and the other is the module that works the agitator.. The module when it fails will not spin the motor so I seriously suspect that the capacitor has failed giving you a direct short to earth
Jun 01, 2013 | Washing Machines
Simpson Espirit water not Filling
try removing your cold water hose and check to see if the screen filter has a calcium buildup or some other obstruction.  if not that then possible bas inlet valve on washer.
Aug 03, 2010 | Washing Machines
THE TECK SAYS THAT THE SIMPSON ESPRIT WILL ONLY
you can pick up a Y adaptor from a hardware store and fit a cold feed to both, it will take a few more minutes to comlpete cycles thats all, all new machines are fitted with a cold feed only to make them more energy efficent. the tech is talking pi**
Jul 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Simpson 175 HD washing machine Programme keeps stopping Is it the timer or some other problem
image_bubblequestion_04.gif Can you please identify the problem with my washing machine?It appears all the functions of my simpson 175 washing machine work normally except the agitator only moves briefly and harshly for between 1 and 2 seconds.
Simpson 175 HD (Dual Action Agitator) Washing Machine.
1517 5M40 A 28 June 1990
Jul 12, 2008 | Washing Machines
Washing Machines Logo
160 people viewed this question
Dan Webster
Dan Webster
Sal De
