Question about Dell OptiPlex GX620 PC Desktop
Optiplex G620 has "munged" BIOS Admin password. Children plaed and saved. Any idea how to clear it ?
  • James Bradburn
    James Bradburn May 11, 2010
    You will have to go in an clear the cmos.
    Open your case and check for the cmos jumpers
    when looking for the
    jumper / dipswitch the label of that switch can be anything;
    however, in most cases will be labeled CLEAR - CLEAR CMOS - JCMOS1 - CLR -
    CLRPWD - PASSWD - PASSWORD - PWD.
    Tell me what you see. and get back
  • Dell Master
  • 4,806 Answers
Hi there.
Try clearing the cmos Optiplex G620 has . move the plastic jumper the alternative position, power the pc up (Nothing will happen if you have it correct, then put it back in its original position and try to boot the machine again, password should be removed.
Good luck and thanks for using Fixya!!
Posted on Feb 13, 2009
    Scholar:
  • 53 Answers
Open the case and find the CLEAR CMOS jumper, change it's position and let it stay for about 20 seconds, the revert it to the original position.
You can instead unplug the pc from the power outlet, open it, remove the battery from the moderboard(it's a coin sized battery that's easy to see and usually has some latch to slide it out),let the pc rest for about 2 minutes or so, and put the battery back into  its place. close the pc side door, and Voilà! it should be back to life.
it will take a little longer than usual on its first boot and might beep a few, it's all ok.
My dell desktop asking for a password
If you want to create a new Basic Input/Output System (BIOS) password on a Dell Optiplex 745, reset the password. Resetting the password also applies if you want to remove an existing BIOS password. BIOS passwords are used to add an additional level of security to your machine. Without the correct BIOS password, your Dell Optiplex 745 will not complete the boot process. The password can be reset whether you know your current password or not.
Turn off your Dell Optiplex 745. Start the computer. Press "F2" the moment the Dell logo appears on the screen. You will only have two to three seconds to press the key. Enter your BIOS password. Navigate to the "Exit" screen. Select the "BIOS Password" setting. Enter your BIOS password and a new password if desired. Do not enter anything in the "New Password" box if you want to remove the BIOS password completely. Press "Enter" to save your password settings. Reset Forgotten Passwords Turn off your Dell Optiplex 745 and remove the power cord from the computer. Disconnect any external hardware and cables. Slide the release latch located on the back of your Optiplex 745. Lift the cover as you slide the latch. Hold the cover firmly and pivot it back on the hinges. Remove the cover from the hinges. Find the "PSWD" jumper on the motherboard. This is a two-pin jumper and should be clearly labeled. Use a flashlight and magnifying glass if you have trouble locating it. Remove the jumper from the motherboard. Replace the cover and slide it into place until the latch snaps into place. Reconnect the power cable and restart your computer. Shut down the computer after it has completely restarted. Disconnect all cables and remove the cover again. Replace the PSWD jumper. Replace the cover. Reconnect all cables and restart your computer.
b> Clearing forgotten passwords http://phubner.eng.ua.edu/Files/Optiplex 745/advfeat.htm - wp1117484
Mar 20, 2013 | Dell OPTIPLEX 745 PC Desktop
Can i make quadro core my cpu dellpentium4 optiplex G620
No, you wold have to replace the motherboard and that would negate any savings of not replacing the system
Single core P4 is all
Mar 25, 2011 | Dell OptiPlex GX620 PC Desktop
I shut my Dell Optiplex 745 off and when i turned it back on Windows doesnt recognize my password. Ive tried everything. Even deleted the system and admin passwords in the BIOS. I keep getting logon...
yes whats your address i have a program on cd that will help......... e-mail me at patcheen2@gmail.com. this will clear your passwords and allow you to get back in to your syatem
Oct 28, 2010 | Dell OPTIPLEX 745 PC Desktop
Floppy disk failure but do not have a floppy disk Dell optiplex G620 have tried to remove it from the BIOS but dose not let me
There should be a setting in the BIOS to ignore errors so you can get it to boot. It's usually set to halt on all errors by default.
May 06, 2010 | Dell OptiPlex GX620n PC Desktop
I just want to have to put my password in when computer turns on. thanks!
For that when you power up the computer press F1 or F2 or "del" key to enter in bios setup screen.
Then go to security then set admin password it is for bios and set user password it is for starting password for computer .
Then enable option "check password always."
Then save and exit setup.
Let me know if you need more assistanse.
Thanks.
Sep 14, 2009 | Acer Aspire 3680 Laptop
Unloked setup dell
If you never set up a password try Admin
Jun 23, 2009 | Dell OptiPlex GX280 PC Desktop
Dell optiplex g620
Check your BIOS. If it rebooted chances are it might work if you change the way the BIOS sees and boots the devices. Try rebooting without the flash drive in. What happens?
Please remember to rate my solution!
May 07, 2008 | Dell OptiPlex GX620 PC Desktop
PASSWORD PROBLEMS
Hi, To access or enter motherboard BIOS settings, on powerup either F2 or Del. If you just want to remove the password in your Dell Optiplex > The BIOS password may be cleared by removing the password jumper (PSWD) on the motherboard. This will also clear all CMOS settings: Open your casing, on your motherboard. find the CMOS password reset jumper (3-pin) on the motherboard; Remove the jumper from pins 1 and 2 and put it on pins 2 and 3 for about 5 seconds. Replace back the jumper on pins 1 and 2. Hope this be of help/idea. Good luck and kind regards.
Aug 27, 2007 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX620 PC Desktop Logo
597 people viewed this question
Alun Cox
