Question about Car Audio & Video
Hi trying i have connected alpine 7871E to alpine fv340 amp. The radio works fine, but when the cd is used the power to the amp is disconnected - so no sound from the speakers. Is there a switch in the head unit that needs to be operated to get the cd sound signal to flow to the amp? Can the cd signal be bypassed any other way? Or is this cd headunit not suitable for connection to a separate amp?
  • m4ddox Feb 13, 2009
    The wiring is ok - the radio & CD are the same head unit.
  • m4ddox Feb 14, 2009
    The problem is fixed some clown had connected the arial to the amp.
    Thanks
  • 19,396 Answers
Good to know the problem is fixed, please give us feedback.
Many thanks.
Posted on Feb 15, 2009
    Genius:
  • 2,920 Answers
Its not set up for a separate amp. i looked it up and also called an audio plcae here with the info you gave and its not set up for a separate amp.
Posted on Feb 13, 2009
  • 142 Answers
Recheck your wiring, it sounds like you may have had a connector come loose from behind the head unit.
    Top Expert:
  • Car Audio & ... Master
  • 63,291 Answers
Is your amp connected using RCA cables?
    Brigadier General:
  • 8,619 Answers
Hi!
Please hook up the remote wire and the power antenna wire to the blue factory amp wire. This will let you hear the sound when cd is played.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Feb 13, 2009
    After the above step is performed, then remove the detachable front panel. Behind the front panel, to the right of the connector, there is a small hole.
    Using a ball-point pen or other pointed object, press the RESET switch mounted behind this hole.
    This will reset your system and you will be able to haer the sound again from cd.
  • Rylee Smith
    See this connections diagram for your alpine 7871E---
  • 296 Answers
If you have your blue remote wire connected and it turns off still, then you can run it to a switch off the fuse block to the remote turn on to the amp, but connect it to a spot the works only when the ignition is on.
  • 679 Answers
Check all wires on this unit.
  • rockfixya
    rockfixya Feb 13, 2009
    There is no switch like you says. It seems there is some short connection between cd and radio amplifier.
    Check that using a bypass wire from cd to amp.
Try change my car radio cd .after connecting electric power and audio cable the new radio panasonic start 1 minute and stop loss power i reconnecting the old car radio ask me for cood the car is
You need to enter the radio code.....this should be with the service book or handbook, or contact the main dealer who will have a record of the code!
Jan 26, 2015 | Car Audio & Video
Fm works, am does not
Check the antenna connection. A poor connection will often be good enough for FM but make AM reception so bad the the radios auto-gain circuits will mute the output unlike old AMs that would just produce loud static in poor signal conditions.
Apr 17, 2014 | Car Audio & Video
Can't switch to the auxiliary
try useing it.. plug your aux cord into whatever your using (mp3 player) as maybe your radio won't switch to aux until it senses that there is audio being played through the input aux cord?
Mar 20, 2013 | Car Audio & Video
1992 GOLDWING RADIO SPEAKERS NOT WORKING
All you can do is trace the wiring back from the radio to the speakers, there is no quick fix here. To test the speakers touch a battery to the two contacts, the speaker will pop if it is any good.
Nov 06, 2012 | Car Audio & Video
No power to amp
check and try finding another grounding spot
May 16, 2010 | Lightning Audio B4.250.2 Car Amp
Lightning audio b150.2 as soon as +12 is hooked up blows 25 amp fuse and the c2 1000uf/35v capacitors blow???????
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you.
Aug 25, 2009 | Lightning Audio PC2 Capacitor Car Audio...
RCA CABLES
RCA cables are the best way to get the audio from your head unit to the amp. If your head unit doesn't have RCA outputs, you might be able to use the speaker outputs of the head unit to connect to the "high power" or "high level" inputs of the amp, if the amp has such inputs (check your manual).
Mar 23, 2008 | Lightning Audio LA1.300.2 Car Audio...
Car Audio & Video Logo
154 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
