Question about Kenwood DNX7100 Car Video Player
Dim Mode I have the kenwood DNX7100 and unit will not auto dim at night and has to be set manually. It is extremely diffucult the next day in day light to turn off. What can i do to make it operate with headlights? Second problem: How do you adjust the light on the dvd? At night this is to bright for the vehicle. Needs to be dimmed as well.
  • 3 Answers
Make sure the orange wire with white stripe is connected to your dash illumination/parking lamp circuit. There should be a tag on it that says 'ILLUM' (unless the installer clipped it). That should dim the display whenever your lights are on.
If that doesn't do it enough I think your going to have to dial down the brighness - and that will do it for all functions.
Posted on Feb 20, 2009
  • steven4mcg Jun 23, 2011
    Auto dim works on all screens except the Navigation/map screen. Nav screen is too bright at night.
Malfunction
Hi - You can download the manual from the link underlined in blue below:
CDX-R3300
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 03, 2008 | Sony CDX-R3300 CD Player
2000 GRAND CARAVAN: Extremely dim headlights, because headlights are so narrow. Installed 9007SU Silverstar Ultra bulbs 3 years ago. Age 77 so poor night vision + still DIM headlights is BAD at night! ...
The silverstar bulbs while brighter, have a considerably shorter life span than conventional bulbs. If the headlights are dim, it would mean a bad electrical connection most commonly a bad ground. If they are just too dim for your liking and burn at the normal brightness, you might want to consider having auxilliary headlamps installed.
Jun 23, 2011 | Dodge Grand Caravan Cars & Trucks
Nuvi 205w screen won't light- any ideas? it's brand new and fully charged. I can tell it's on, because it generates sounds when I touch the screen.
If you can't see anything then it is a hardware issue. Return for replacement as soon as possible.
If you can see faint images in the background then your screen is just too dim. You will have to try to navigate the dim screen to the settings menu. Click on the Tools icon, bottom right of main screen. Click on "settings" then "display". Select brightness and adjust.
One other suggestion is try an update. Plug the unit into your PC and run garmin webupdater. Once done the screen may light up but its a long shot. Here is the webupdater link.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Cheers
Jul 13, 2010 | Garmin nuvi 205W GPS Receiver
Dim Screen on the 2001 Toyota Prius
Yes the screen dims automatically when the lights are on to suit night driving. I am not specifically familiar with the 01 model, however on my 08 model, the display brightness is also manually adjustable via a button located below and to the right of the display. The button is marked with a series of short lines assembled in an arc. Hope this helps.
Nov 25, 2009 | 2001 Toyota Prius
I have a lock symbol next to some of the icons in the setup menu and it won t let me select the. The unit it a Kenwood DNX-7100.
Pg. 82 in the manual:
Under Step Up > Set up Memory (last page of options) > Select Unlock.
I also had mine set up lock.
Apr 14, 2009 | Kenwood DNX7100 Car Video Player
DNX7100 Remote inop
The problem I had was with the remote control unit for the steering wheel controls. It shorted out. The head unit was fine. But, when the sterring control unit is shorted it also prevents the hand held remote from working.
Jan 01, 2008 | Kenwood DNX7100 Car Video Player
Reset
In other words, it's STOLEN! Nobody help this guy.
Dec 05, 2007 | Kenwood DNX7100 Car Video Player
Display
It does not auto dim, it just remembers the settings. As soon as it has a GPS fix and knows the correct time it will switch to either day or night mode, and use the last setting you chose for that mode. Just give it a minute or so to get that GPS fix.
Mapsource, you mean the one on the PC? That you can upgrade by downloading it from Garmin, If you mean the maps on the GPS, you gave to order the DVD from Garmin and pay for the unlock key.
Sep 12, 2007 | Garmin zumo 550 GPS Receiver
DNX7100 - new unit, screen won't power up
It only goes down half way. You have to gently push it down the rest of the way to expose the SD card slot.
Aug 23, 2007 | Kenwood DNX7100 Car Video Player
Kenwood DNX7100 Car Video Player Logo
239 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
