Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher cleans but will not drain.
My Bosch Dishwasher SHX46A05UC/23 runs and cleans but will not drain. Any thoughts? Does anyone know where a I can get a service manual? I'm thinking the drain motor bad.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Posted on Feb 15, 2009
My bosch shx46a05UC/14 will not shut off. I can open the door and the dishwasher just keeps going?
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Jan 28, 2011 | Bosch 24 in. SHX46A05UC Built-In...
My Bosch Dishwasher model shx46a05uc/46 will not drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 20, 2010 | Bosch 24 in. SHX46A05 Stainless Steel...
Bosch Dishwasher SHX46A05UC/23 - No Water
Sounds like your recirculating pump is clogged If it is water can't get up enough pressure to turn the sprayers.
You'll need to start pulling parts out of the bottom inside to get to that pump. I don't work on a lot of Bosch, but that sure sounds like it to me. I see this a lot. Hope this helps...
Nov 28, 2009 | Dishwashers
Bosch SHX46A05UC/30 runs for 4 hours.
The circut board in the biege plastic case under the buttons on the right has what is called a cold solder. In other words the solder melts under operational use. Some are repairable and some are not.
1. UNPLUG DISHWASHER or turn off breaker and test for electricity.
2. Remove screws from door panel.
3. Take pic of position of wires going into plastic box.
4. Remove top section of plastic box with buttons exposing small circut board.
5. Open plastic box exposing large circut board and in the middle of it you will see a black spot where the solder has popped. Resolder and reassemble OR replace old circut board and then reassemble.
A new circut board is about $135
Usually electrical parts are not returnable
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-1.jpg
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-2.jpg
/uploads/images/bosch-shx46a05uc-30-runs-4-hours-23453222-3-3.jpg
Oct 23, 2009 | Bosch 24 in. SHX46A05UC Built-In...
My Bosch shx46A05UC no longer will drain.....it
I ran into the SAME problem with my Bosch SHX46A06UC /21. The problem ultimately ended up being a clog in the air gap vent, (meaning, SOMEBODY ran the dishwasher without the bottom filter being in place or not in place properly). Remove the air gap cover and upper surface nut to drop the air gap vent into the area under the sink. Disconnect the hoses from the air gap vent filter (placing a bucket under the hose from the dishwasher). Run the drain cycle on the dishwasher. The washer should drain into the bucket and let you know that your pump works and that there are no clogs or kinks in the drain hose. (This will also remove the clog if so). The air gap vent's smaller hose connection is MOST LIKELY where your clog is. Look at the upper end of the air gap vent. You'll see a couple of clips on opposite sides of each other, that hold the air vent cap in place. Using a small screwdriver, (or your hands if you can), depress the clips (or one at a time) to get to the point where you can pull the vent cap off the filter. Either use water or a thin, long blade screwdriver to force any objects out of the filter. You should now have full flow through both branches of the filter. Using water and a rag, clean the vent cap and filter. Mount the air gap vent filter back onto the sink. Reconnect the hoses and remove the dishwasher's internal filter(s) and clean them as well while you're at it, making sure to remove any debris that might remain underneath the filter and has the chance of clogging the unit again.
Run the washer again to test. You should be good!
Cheers!
Oct 13, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
Dishes do not clean same detergent and rinse no change to amount
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jul 06, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Bosch Model shx46a05Uc/14 not running
Unlikely to be a level problem. Remove the filter and two screws holding the cover over the wash motor impeller from inside the wash tank - check for something jamming the impeller, like bits of broken glass or fragments of bone, fruit pips etc.
If not that, check basics - water supply, drain hose, filters clear, not syphoning empty, etc.
Feb 02, 2018 | Bosch 24 in. SHX46A05UC Built-In...
Dishwasher motor runs (even with door open), but no Water
I believe the problem is in the electronic board. It is getting a different signal thus not allowing it to run properly. You can have a local service technician for the company look at it but this is probably the cause.
Dec 25, 2008 | Bosch 24 in. SHX46A05UC Built-In...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
886 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
