Question about Digital Concepts Digital Camera
Camera says protected card
When i put my SD card 2GB into my 7.1 megapixel camera it will not let me take any pictures it says protected card how do i fix the problem
  • 4,806 Answers
Hi there
Take the card out and unlock it, it will be at the side of the card like this camera says protected card - 59a6de4.jpg .
Good luck and thanks for using Fixya!!
Posted on Feb 13, 2009
Message says memory card is write protected and does not allow me to take any more pictures
What kind of card is it? An SD card? If so, there should be a little tab/switch on the side of it that you can flick to resolve the issue. If not, have a look at this: How do you remove write protection from mini SD card
Sep 29, 2014 | Nikon Coolpix L26 16 Megapixel Digital...
PROTECTED CARD CANNOT DELETE PICTURE
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 03, 2013 | Fuji Finepix S1500 10.0 Megapixel 12x...
Screen says "Memory Card Protected" and will not take pictures.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2012 | Fujifilm FinePix C10 3x Optical Zoom, 10...
Camera says write protect when trying to take picture
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 04, 2012 | General Electric GE A1255 12.2 Megapixel...
Gateway digital camera DC-T50 5.25 megapixels put new memory card and a card error message appears
The camera uses SD cards. I assume your new card is 8GB, not 8MB as you stated. If this is the case, it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the SD-only camera. You need to use SD cards, 2GB and smaller.
You may download a copy of the manual here.
Apr 04, 2012 | Gateway DC-T50 Digital Camera
VIVITAR VIVICAM 4090 PURCHASED FROM SHOPPING CHANNEL IT SAYS IN MANUEL UP TO 2GB . ON THE BOX THERE IS A STICKER SAYING USE UP TO 2GB BUT UNDER STICKER IT SAYS UP TO 8GB . CAN I USE A BIGGER GB OTHER...
The box may say you can use a card up to 8GB but since it can only use SD cards (not SDHC), the box seems to be in conflict with reality. Besides, the camera is only a 4 megapixel camera so you will be able to take hundreds of pictures with a 2GB card.
Jun 07, 2011 | Vivitar Cameras
I have a fujifilm 12.0 megapixel camera .it has a fujifilm 2gb memory card and it keeps saying protected card, could you tell me why its doing this
The card is most likely an SD card which has a lock on the side of it to protect pictures from deletion sometimes this switch gets pushed in the wrong direction. I'm including a "generic" picture/diagram of this switch.
Also you will need to format the memory card before it will work properly and be totally compatible with the camera you will need to look in your camera manual for this information. You didn't give me the model of the camera or I would have been able to direct your to the correct page. Once the memory card has been formatted everything should work just fine.
Dec 31, 2010 | Photography
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Would like more picture capability . . .
Your Vivitar Vivicam 5385 accepts SD Card cards.The largest SD Card card you can use in your Vivitar Vivicam 5385 is 2GB.
This link will take you to an online store, the Panasonic 2GB SD card is £5.99 Delivered.
http://www.mymemory.co.uk/SD-Cards/Panasonic/Panasonic-2GB-SD-Card-%28Secure-Digital%29
Simply insert this into the slot on your camera and you should be good for well over 800 to 1000 pics.
Best wishes and hope this reply helps.
Mike.
Mar 02, 2009 | Vivitar ViviCam 3330 Digital Camera
SD card
wahoo!just been rummaging the internet and i have found that these cameras will only take up to a 1gb memory card!so just get a smaller size card
The camera has 16 MB of internal memory. Memory capacity can be expanded with 16MB, 32MB, 64MB, 128MB, 256MB, 512MB up to a maximum of 1 GB SD or MMC cards.
Hope it helps!!!
Jun 23, 2008 | Kodak EasyShare C330 Digital Camera
Digital Concepts Digital Camera Logo
44 people viewed this question
Top Digital Concepts Cameras Experts
Robert
Tony
Are you a Digital Concepts Camera Expert? Answer questions, earn points and help others
