Question about Car Audio & Video
CD eject button stuck in. Tape won't eject either
Problems started with the volume control being erratic and nice CD's skipping and sound scratchy fuzzy. I got angry and punched the dash, now the eject button is stuck and pushed back. The one CD stuck in there will play, but it's getting old. The tape player won't play or eject the tape, it acts like it wants to but gets caught up. $190 to fix it at a shop, I don't have extra cash for that. Can I do it myself?
  • Anonymous Mar 31, 2014
    A cd is stuck in the player of my kia optima. I am told there is a reset button for the cd player, but I cannot find it. Can anyone help
  • 24 Answers
More than likely you broke the eject part of the board off of the rest of it, you could the radio out of the car and pull off the plastic front and taker a look
Posted on Mar 04, 2009
SANYO FXCD-500 has CD Stuck inside player. Radio & Cassette Still Work. It is Still in Dash of my Toyota 4x4 Pickup. Besides taking unit out of Dash??? Any Suggestions??
Sanyo FXCD-500 Operating Instructions Manual - ManualsLib
www.manualslib.com > ... > Sanyo Manuals > CD Player > FXCD-500 FXCD-500 CD Player pdf manual download. ... cause a deterioration in the sound or intermittent skipping some tracks during play This unit has ... TAPE OPERATION 109876 LOADING AND EJECTING THE TAPE Insert a cassette into the tape ..
Mar 30, 2015 | Toyota Cars & Trucks
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
Pinch roller stuck in "up" position, eject button won't open door
The very first mistake is to pry a door open. That damages them. You are never to do that. The correct way to get a tape out is to open the unit up and find out why the tape is stuck and then take action to release the door in the normal way- usually it is a loose belt or defective cam motor. As to the Pinch roller there are slide plates and even some pinch rollers had lubrication on them so that may have dried leaving you with a stuck part. The normal order of business is the find out what is stuck and then take action to clean and lubricate the mechanism to return to normal function. The problem with some Pinch Rollers is that there may be a particular spot it needs to be set at. This is true if it has a guide fitted to it. Then you will need either a jig or mirror tape to be able to set it correct again. I can not give any further advice without seeing the unit but this should get you started.
Dec 03, 2012 | Audio Players & Recorders
I have a NV-DX110B about 11 years old. I'm getting
Your camera appears slightly older than mine so I will do my best for you. Have you tried ejecting the tape with the power off? If I have problems I slide the eject button when the camera is off but plugged in and the tape can be ejected. I suspect the tape mechanism is in trouble. When a tape stuck in mine I had to literally force the cover open. But this is a last resort.
Give my suggestion a try and apologies if you have already tried that...
Sep 11, 2011 | Panasonic Video Cameras
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Cd stuck in the player
You can use another old CD and some very sticky tape (like duct tape).Take a peice of tape about 2 inches long.Fold it so it's half the lenth and sticky on both sides.Adhere it to the end of the old CD so its flat and will adhere to the other stuck CD.Slide the old CD w/the tape on it(aimed down) in the CD slot and while pressing the eject button and adhere it to the stuck CD and pull.It should stick to the other CD and dislodge it
Sep 13, 2009 | 2004 Chevrolet TrailBlazer
Tape stuck in player - error code e13 shows
I just got a tape unstuck myself. Everytime I would hit eject it would make a clicking noise.
Here is what I did:
First I watched these videos to remove the radio.
http://www.youtube.com/watch?v=29MTa4FLjtk&feature=channel
http://www.youtube.com/watch?v=fqvk_PNo9Kg&feature=channel
Then I unscrewed the bottom panel of the radio.
Unscrew the brass screws holding in the cassette player portion of the radio.
Now flip the cassette player over to see your tape, etc.
When I pressed the eject button, I noticed a little motor with a worm gear would move a a gear which moved several other gears until it eventually moved a black gear which has a little post that moves the metal arm which moves back when pushing in a tape and moves forward when ejecting a tape. But I would get a clicking sound which seemed to be due to one gear trying to move a stuck gear.
I forgot the exact details of how I managed to get the tape out, but when I did get it out I noticed when I turned on the radio, it would act like it was trying to play a tape. But when it found out it couldn't, it would try to eject but would fail once again with the gear clicking sound.
I think I tried moving the black post on the black gear that moves the arm that pushes the tape out. Eventually I got to the point where the arm was pushed forward like it should be when a tape is ejected. At that point I was able to insert and eject a tape without any problems.
Mar 22, 2009 | 1998 Buick LeSabre
Numark CD MIX2 right deck skipping, sounding scratchy
Did you by any chance buy it from a b stock retailer?...send it back...also reduce your burn speed when recording cds
Aug 04, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Car Audio & Video Logo
126 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
