Question about Samsung CLP-500 Laser Printer
SAMSUNG 500 PAPER CHANGE
I DO NOT KNOW HOW TO CHANGE SIZE OF PAPER
    President:
  • 2,692 Answers
How do I get it out of envelope mode
usually when you try to print another box appears to set paper size and type
Apr 14, 2015 | Kyocera FS2020D ECOSYS Monochrome Laser ...
What is a5 size
A5 is the size of 148x210mm based on ISO 215 norm for paper
Format A series[3] B series[4] C series[5] Size mm × mm in × in mm × mm in × in mm × mm in × in 0 841 × 1189 33.1 × 46.8 1000 × 1414 39.4 × 55.7 917 × 1297 36.1 × 51.1 1 594 × 841 23.4 × 33.1 707 × 1000 27.8 × 39.4 648 × 917 25.5 × 36.1 2 420 × 594 16.5 × 23.4 500 × 707 19.7 × 27.8 458 × 648 18.0 × 25.5 3 297 × 420 11.7 × 16.5 353 × 500 13.9 × 19.7 324 × 458 12.8 × 18.0 4 210 × 297 8.27 × 11.7 250 × 353 9.84 × 13.9 229 × 324 9.02 × 12.8 5 148 × 210 5.83 × 8.27 176 × 250 6.93 × 9.84 162 × 229 6.38 × 9.02
Paper size Wikipedia the free encyclopedia a5-size-jvq5yflo2qhjwukzjlpzf0ie-3-0.jpg a5-size-jvq5yflo2qhjwukzjlpzf0ie-3-2.jpg
May 18, 2014 | Epson Stylus NX400 InkJet Printer
Downloaded jar are invalid in my gt e2222
You have landed on this page because you tried installing an application in your Samsung phone only to be prompted by this error: "JAR file is over max size" And now, you are looking for the solution for this error. I want to share to you the secret code that will resolve this "JAR file is over max size" error. I have tried this in Samsung Champ and it works. I am not sure if this will work in other Samsung Units, but it's worth a try. The reason why this error is prompted is because the default value for a jar file in Samsung units is 500 KB. So if your installation file (which is always in .jar file) is more than 500 KB, you cannot install it. But, I found a way to install .jar files which are more than 500 KB. Just follow this procedure. 1. In your keypad, type this code: *#52828378# 2. You will get the JAVA Test Menu after typing the above code, find the OTA Test menu and open it. 3. Then you will see the value 500 in Maximum JAR size field, change the value to a number higher than 500, i.e. 5000. 4. Save the setup 5. Now, go back to your jar file and install it You should be able to install it now.
Sep 25, 2012 | Samsung GT-E2222 Unlocked Cellphone - US...
Lexmark T632 has 2 (ea) 500 sheet drawers, but once the paper runs out in Drawer 1 it will not automatically pull from Drawer 2. Please advise how to fix this problem.
go to Menu, reports, and print out the top report.
This will show you what the printer sees as the default tray, and what paper size and type are set for each tray.
If you have plain paper in each tray, make sure that the setting page also shows that each tray is set to letter, plain.
This printer sets the tray type automatically, based on the way the tray is set. There are little tabs on the side of the tray that change as you change the size of the paper with the paper guides.
If the paper guide is set even one click off, this can cause the printer to read the paper size incorrectly, and thus will not change to the next tray. ( if it thinks that tray 2 is A4 paper, but you are printing letter, it will not change to tray 2).
if the trays ARE set correctly, but the printer is still reading it wrong, then there could be something wrong with the sensor ( metal fingers and switch ) inside the printer.
Feb 15, 2011 | Lexmark T632 Laser Printer
The copier is flashing at the "error" light and the screen reads "change reccomended size, common settings" I don't know how to change it
To change paper size on Drawer 1, Go to Additional Functions > Common Settings > Reg Paper Size > Drawer 1 > Paper Size > (Select the correct paper size) > Press Ok
To change paper size on Stack By-Pass, Go to Additional Functions > Common Settings > By-Pass Std Set > (Select ON) > Paper Size > (Select correct paper size) > Press Ok
Oct 24, 2010 | Canon imageRUNNER 1023iF Black and White...
HP Laserjet 2430n printer won't see the paper in Tray 2. Continues to give in display paper size *letter and *plain but I set it and it just comes back asking again. When you print it won't pickup from...
Yes I checked the tray throughly. I also changed to paper to legal plain and changed the configuration...still came back on the display panel change paper size...just won't stop asking.
If I put the add-on paper tray 500 sheet that tray works fine.
I was thinking though I might order another paper tray and try it since I replaced the pickup assy and still have problems...what do you think
I also cold reset the printer just in the event something was set wrong...still has problems
Oct 15, 2010 | HP LaserJet 2430tn Printer
"Jar file is over max size"
Every phone has a different maximum jar size limit and when you accour this rate you will get this error message. There is no solution to solve this problem. You can't install this jar to your phone.
Jun 28, 2009 | Samsung J700 Cellular Phone
Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
May 21, 2009 | Ricoh Aficio 1013F Copier
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Samsung CLP-500 Laser Printer Logo
63 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
