Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
High Squealing Sound
My RCA Big Screen TV Model # D52W25 with HDTV monitor creates a high squealing sound after watching for a few minutes. And the sound is too piercing that you can not stand it.
    President:
  • RCA Master
  • 1,779 Answers
There is a stand up coil about 1" tall and the dia of a nickel close to the HV transformer, the iron core glue comes loose over usage. This can be cured by replacing it or using a sealer/caulk and re-seal the coil. Hope this helps, it is not an expensive job for service.
Posted on Feb 13, 2009
My tv makes 3 even high pitched squeals when i turn it on. about 1 second each, then powers off. No picture no sound. All imputs. What do you have for suggestions on what it could be.
One of most two common reason why your set will not come on, is because it has lost the high voltage, the first thing to check is your horizontal output transistor, to see if it is shorted, it will be located bay the flyback, mounted on a metal heat sink. That is what is causing a squealing noise.
Oct 16, 2010 | RCA HD52W56 52" Rear Projection HDTV
Makes a squealing sound but there is no picture on the screen
Hi
The squealing sound that you hear most likely comes from the power supply.
And it is most often caused by a shorted horizontal output transistor.
But that would have to be determined by opening the set and testing it. It is a common problem in rca`s and other sets, it is often caused by a bad flyback(high voltage transformer) and/or associated circuitry.
Hope this help to clarify things a bit.
P.S please do not rate this answer(unless it helps)as it is only a suggestion/information.
Dec 13, 2009 | RCA 36V430T 36" TV
Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
Oct 07, 2009 | Toshiba REGZA 47HL167 TV
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Loud squealing noise first 5 minutes after tv is turned on
Sounds like the color wheel. It's the only moving part in most DLP's and the bearings can go bad. If it manages to get up to speed the picture may look normal. One temporary solution may be to let it run a few minutes, then turn the set off for 10 minutes, then turn back on. When my color wheel was going bad that would often quieten it down. For the rest of the day, try to leave the set on, especially if you're only going to be away from the TV for short periods. You can turn off your cable or satellite box but leave the set on and you won't have to go through the hassle of trying to quieten down the color wheel until the next cold start. Of course the best solution is to replace the color wheel which even with a rebuilt unit won't be cheap if your warranty is expired.
Nov 02, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
152 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
