Question about Saeco V-spresso Espresso Machine
Vspresso - extra part after cleaning
I just finished cleaning my Saeco Vspresso and noticed an extra part in the sink. I'm not sure where it goes.
If you have a background with this machine, let me know and I'll email you the picture
  • 24 Answers
Your picture shows a cylinder shaped plastic piece with two different diameters. There is a slot in the small end.
This piece fits inside the upper piston. It fits on the upper piston screen screw with the slotted side away from the screen and serves as a seal around the screw. The thumbscrew has two pieces which fit into the slot.
John
Posted on Feb 18, 2009
Saeco vspresso boiler removal
open the machine and see where exactly leaking. If is from boiler you have to change the seal between the two biler parts.
Dec 29, 2013 | Saeco Coffee Makers & Espresso Machines
The steam / hot water function on my saeco Vspresso does not work. It has intermittently worked in the 10 months I've had the machine, but I can't descale without this function. any ideas? I turn it on...
First check to make sure that the end of the steam spout is not blocked, use a paperclip. If you machine has a parnello on the wand check to make sure that the holes on that are not blocked also. If those are clear, then when running the hot water cycle push in knob if that works the the tap rod assembly on the steam valve needs to be replaced.
Oct 09, 2009 | Saeco Vienna De Luxe Espresso Machine
I have saeco v'spresso -- LCD screen is not readable.. how can i replace?
NEWS FLASH!! A replacement screen IS available. The original part has been discontinued but the display for the Magic Comfort works. The only difference is the color. The original display was orange and this one is green but IT WORKS perfectly. I just replaced it myself. The part number and description are "0332817 Pcb, DISPLAY MAGIC COMFORT". I ordered it from Saeco Outlet @ 800-933-7876
Jul 06, 2009 | Saeco V-spresso Espresso Machine
The fabric softener tray is full of water when wash has finished
The 2 probs could be related.
The first you need to do is remove the dispenser drawer, and thoroughly clean every part of it, particularly the conditioner compartment, poke clear all the tubes and apertures you can see,the problem is caused by a blockage.
The smell is related to the fact that the waste pipe is probably connected to your sink waste, you need to remove the pipe and check for partial blockage, or if it goes to an outside sink , then you need to get some kind of drain cleaner to pour down the sink..
Also , at least once every 6 weeks do a hot wash with powder, but no clothes in, this helps to keep the m/c clean and prevent build up mould and dirt inside the m/c..
Clean the door seal regularly, when you finish a wash.and leave door open and dry it
This should help disperse the smell.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Hotpoint Ultima WD72 Front Load...
Descaling warning
Try pressing the ESC button.
If that does not work, go to the menu (press M), use the up and down arrows until you go to Descaling. There should be a function in the menu to turn off the warning. While in that screen, try the ESC button.
Dec 10, 2008 | Saeco V-spresso Espresso Machine
Extra part
Eric...do you have a photo of the part?
Paul
Oct 25, 2007 | Saeco Royal Professional Espresso Machine
Saeco V-spresso Espresso Machine Logo
96 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
