Question about Poulan 12a Elec Blower/Vacuum
Recoil spring broken
I need to replace a starter recoil spring on a poulan blower. Which way does the spring face?
    Master:
  • 505 Answers
You need to supply the brand and model of the blower so i can look it up
Posted on Feb 15, 2009
Rewind pull cord poulan pro snowblower pulled cord first time and will not rewind back
If you are a fix it kind of guy you can remove the starter assembly and check the recoil spring.
Dec 19, 2013 | Poulan Garden
I have a poulan pro backpack blower (the 30cc one) and recently tried to start it and the rope extended all the way and won't recoil. i pulled it apart and can see the pulley inside the cover, but how do i...
The recoil spring might be broken or unhooked from the pulley. You would have to remove the pulley to find out what the problem is. But doing this, the spring could uncoil from the spring housing and it is dangerous that it could hit you in the face if you are not very careful. The spring is very difficult to rewind into the housing. I would bring it to a shop if I were you. Whatever you do, good luck.
Nov 22, 2010 | Garden
How do you replace spring on a poulan chainsaw
A Poulan "P4018WT Gas Saw Type 1" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
If yours is not a "Type 1" it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If the spring is unwound:
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. The video explains how to tension the spring.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I just replaced the recoil \\starter rope on my blower
Are you sure you have the right length rope??? If you are sure the rope length is correct you may have wound the recoil spring too tight causing it to run out of travel. You want the recoil spring just tight enough to pull the rope all the way in.
Wayne
Feb 26, 2010 | Oregon Scientific Complete Carburetor for...
Cant remember how to put the spring back on the pull cord recoil
This reply is based on the following assumptions:
A Poulan PP2375LE (wildthing) Type 2
The starter recoil spring is unwound.
All components aer servicable
Poulan 2375LE Type 2 IPL
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Starter components and reassembly order are illustrated on the "Handle, Chassis & Bar Assembly" detail.
If the spring needs rewound this is how I do it, there are other methods.
I invert and secure the housing and rewind the spring large coil to small (need eye protection, and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool.
This illustrates proper pretension and rope installation:
Smalleng.com (about 3.5 minutes long and worth watching the entire video)
If yours is not a Type 2 you can find the correct IPL here:
Poulan.com
I hope this was helpful
Lou
Jan 29, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How to repair spring starter on FL1500LE
The casing is situated so the spring faces the starting spool. The spool is plastic and the rope is wound around it. The hook goes to the spool. Put it back together carefully! Good luck...Lee
Nov 24, 2009 | Poulan Featherlite Gas Blower, with Low...
The starter pull rope will not retract
The recoil starter spring may need to be replaced or the starter pulley has become fused to the plastic housing. If it is not under warranty; taking to a shop to get fixed may be more than what you want to spend. It may be time for a new one.
Good Day.
Oct 26, 2009 | Poulan Garden
We have a featherlite gas blower model # F1 1500 LE - need part # for pull cord and assembly
Recoil starter pulley - Part # 530071792 (Rope & Handle NOT included)
Recoil starter spring - Part # 545008011
Hope this helps,
Dolf-
Oct 15, 2009 | Poulan Featherlite Gas Blower, with Low...
Rewind a recoil starter spring. I've spent many hours trying to get the recoil spring put back in its place with no luck.
I DID THIS SAME JOB BY WINDING THE SPRING UP IN MY HAND AND THEN TOOK 2 TWIST TIES AND WRAPPED THEM AROUND THE SPRING TO KEEP IT IN THAT CONDITION. I THEN INSTALLED THE SPRING WITH THE LONG END OF THE TWIST TIE EXPOSED AND AFTER GETTING THE ROPE HOUSING IN PLACE I PULLED THE TEWIST TIES OFF WITH SOME NEEDLE NOSE PLIERS. HOPE THIS HELPS
Sep 25, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Jun 27, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan 12a Elec Blower/Vacuum Logo
290 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
