Open close the front door if the code comes back replace the print head which houses the LASER and or the main board is bad. If you can find one very old machine build bye Minolta before merging with Konica now Konicaminolta
The code refers to a sensor that looks at the drum - it might be dirty or something else is going on check this Fixya-link: Minolta DI450 error code C0F24
The C0000 code is that the Fusing Unit (The HOT Part) has a motor and it can not turn or is burned out do jam or gear problems. Could not find anything about 2510
Hey their... The code on your Hub450/550/470 is the toner density not being read. The drum must be removed u will find a sensor under the Mylar(mylar catches the toner wiped from the drum) that sensor is dirty and the Mylar is bad... :-D. PS u can perhaps repair the mylar with tape from the inside... Good luck
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
The Document Feeder has only 1 Malfunction code for any problem with it. If opening and closing the front cover (while it is turned on) resets it and you can use the machine, dont worry about it. The unit was prone to this false malfunction code. If it returns very often, then get an engineer to have a look at it.
The Error Code is C-0072
