Question about Electrical Supplies
Engine will not start after oil dummy light came on.
I filled it back up with oil, and replaced spark plug. its getting gas, but no spark, is it the coil?
  • 52 Answers
There is a low oil sensor above fill stick. See if you can bypass it by taking the sensor out of the loop.
Posted on Feb 14, 2009
Engine snug to turn. not froze up completely. Overfull oil level.
Drain the gas, then drain the oil. Now refill the oil to the correct amount/height. Remove the spark plug and rinse/clean it in some gas. If there is any build up, scrape it out and make sure the gap is correct. Spin the engine a couple of times to actuate everything. If you see any oil at the spark plug hole, spray a small amount of gas through the spark plug hole and spin the engine to distribute the gas. Reinstall the spark plug and put some gas in the tank. Remove the air cleaner, place your hand over the carb throat and spin the engine a couple of times. You will partially flood the engine, but this will thin any oil left in the cylinder and intake/exhaust ports. Replace the air cleaner and try to start the engine as you normally would. You should have compression by now and the engine should be trying to run. If it feels like it is still flooded, remove the spark plug again and spin the engine a couple of times with the throttle in the off position. Reinstall the spark plug after a few minutes and try to start the engine normally. It should run. It will probably be a bit rough and smoke, but this should pass once the oil burns away. If the engine still runs rough after the smoke clears, clean the spark plug again as it may be fouled.
May 18, 2016 | Briggs & Stratton 550 Series Vertical...
I tried to start my bike the other day. Oil came out breather then i forgot and left the fuel on
Hi, Michael your bottom end may be filled with gas remove spark plugs and turn over the engine for 30 seconds clean spark plugs that are probably gas fouled and reinstall get the bike running for a couple of minutes then replace engine oil. Good luck and have a nice day.
Jan 22, 2016 | Motorcycles
My troy-bilt snowblower will not start. I stored it right last winter. I filled it with fresh oil & gas two days ago. I've done the starting procedure over and over again. Added fuel stabilizer and seefoam...
Check to see you are getting spark at the spark plug. Take the plug out and put the plug wire on it and ground the the nut on the spark plug to the engine block and crank the engine and see if you get spark at the plug. If so then your carburetor has to be taken apart and cleaned.
Jan 28, 2015 | Garden
2002 Chevy Tahoe ran out of gas got gas filled it up,started right up drove about 4 miles or less and died out again? Notice check engine light was on?and low engine oil flashed on the dash?So I put a...
you need to do the fallowing :
- make sure that you donr have a n oild leak some where look under the car
- u have a missfire in cylinder number 5 ( it colde be the spark plug or the coil )
if you wana go cheep , start by buying 1 spark plug and change it in number 5 if fix the problem ok if not , get the coil and change it
Jun 25, 2013 | Cars & Trucks
Engine light on, and runs rough
It must be something else making your check engine light come on.
Jun 13, 2017 | 2003 Chevrolet TrailBlazer
My ryobi 350 cfm 180 mph gas backpack blower just stop andwont start again and my brother in-law said my mixture of gas to oil is not correct,less oil was mix how can i remedy the problem.
PROBLEM Engine fails to start. CAUSE - REMEDY No fuel in tank - Fill tank. Spark plug shorted or fouled - Replace spark plug. Spark plug is broken. (cracked porcelain or electrodes broken) - Replace spark plug. Ignition lead wire shorted, broken, or disconnected from spark plug - Replace lead wire or attach to spark plug. Ignition inoperative - Contact authorized service center.
Aug 21, 2011 | Ryobi Garden
My troy built 2200 pressure washer was running fine but then shut off instantly I then noticed it had low oil I filled it but now it won't start
Pressure washer takes oil in two places:
Pump oil is 20-30 weight SAE non detergent and comes half way up/ do not fill more than 1/2 way
Engine oil is 10W30 and comes half way up dip stick
IF you overfilled the oil >>> DO NOT turn power washer on it's side or upside down to drain oil >>> because engine oil will fill carburetor
When engine won't start
We pull off air filter so we have direct access to carburetor
Spray WD-40 into carburetor while starting
The engine will fire on the WD-40
You can keep spraying WD-40 into carburetor to keep engine running while moving choke to see if engine will run on it's own
Squeeze gun trigger so water comes out gun and pump pressure doesn't stop engine
If engine will not fire on WD-40
Spark is suspect
Your spark plug gets power from ignition coil
If coil is bad you get no spark > and coil needs needs replacement
Take out spark plug, clean it with WD-40 and use a bit of sandpaper in the spark gap
Put spark wire back on plug
Touch threads of spark plug to metal part of engine > pull cord and look for sparking between spark plug and engine
If you do NOT have any sparking, then coil is bad
If you HAVE spark, then your spark plug needs cleaning or replacement
If engine fires on WD-40 but will not keep running
Then either fuel or carburetor are suspect
Loosen hex nut on fuel filter located below gas tank >> if fuel flows, then re-tighten hex
Next, pull off rubber hose connected to carburetor to see if fuel flows to carburetor
If fuel is flowing to carburetor, then the carburetor is suspect.
Small engine repair shop will have carburetor cleaners
Check exhaust
There is a screen over exhaust
Make sure it is clean of carbon build-up > Use WD-40
Change air filter
Oct 12, 2010 | Briggs & Stratton Garden
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Electrical Supplies Logo
100 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
