Question about Dell Dimension 4600 PC Desktop
Has no picture,computer makes a noise when turned on etc...
I let a kid that is in 2nd year computer classes work on my pc. He added a cd burner and a few other updates (he said). When I got it back, the computer, when plugged in makes a noise...not a hum but a noise. It doesn't sound like the computer is on though the lights are all lite up on the back and on the power button.
.There is no picture on the monitor at all. It is just a black screen. When I unplug the monitor, the monitor looses the communication , you can tell as it says to plug in your pc as soon as it is unplugged.
For some reason I was told to check that the ram was good. I've changed it but have the same problem. The kid says it worked great on his monitor. I've tried 3 other monitors. Also was told to check the video card. My husband tried 2 others in it, with no results. Do you have any suggestions?
Thank you~
Lori
  • Frank
    Frank May 11, 2010
    power down the computer, open the cover, reseat video card, memories, and any other plugins.
    repower powerup the mchine.
    pst back what happen.
    Scholar:
  • 53 Answers
If you tried with 3 different monitor, then the kid has done a bad job and eventually messed up with some critical system component.(CPU-RAM-Power Supply Unit-Video Card)
check if the CPU fan is spinning, if not this can prevent the system from turning on and you need to replace it.
the CPU might have overheated and therefore it can be permanently damaged.
I'd say it is probably a CPU matter, because the black screen means the PC is not passing over the Power On Self Test.
RAM can cause this too, but if you changed it, it is not a matter of RAM.
Video card is not likely to cause this.
I'd say try to remount the CPU and the heatsink properly, with proper thermal grease after deep cleaning with lint free paper or cloth;
(the only options remaining are: motherboard damaged with screwdrivers and grounding problems caused by spilled thermal grease.)
but first find out exactly what "upgrades" the kid did install, a defective PSU and/or unplugged CPU power cord can cause this.
Posted on Feb 13, 2009
  • 1,602 Answers
TO LORI
YOU NEED TO FIND OUT WHAT WHAT DID HE DO TO THE MACHINE. IF HE PUT A CD ROM BURNER IN IT REMOVE THE FROM THE SYSTEM, REMOVE THE DRIVERS, FIND OUT WHAT SOFTWARE HE INSTALLED AND REMOVE IT UNTIL YOU FIGURE OUT WHAT IS WRONG WITH THE SYSTEM. PUT EVERTHING BACK THE WAY IT WAS WHEN HE TOOK THE SYSTEM, IM ASSUMING BEFORE HE TOOK IT IT WAS WORKING FINE.
IF HE UPGRADED THE RAM THAN PUT THE OLD RAM BACK, WHEN IT IS ORIGINAL AND IT IS WORKING ADD 1 PEACE OF NEW EQUIP[MENT EVERYTIME AND TEST IT BEFORE MOVING TO MAKE SURE THERE IS NO CONFLICKS WITH THE SYSTEM AND SOFTWARE ISSUES, KEEP DOING IT THE SAME WAY EVERY TIME YOU WILL BE FINE AND YOU WILL NEVER HAVE COMPUTER PROBLEMS AGAIN.
AND DONT LET ANYONE WORK ON YOUR MACHINE UNLESS YOU ARE RIGHT THERE AND KNOW WHATS GOING ON AND IN THE MACHINE.
THE PARTS JUST APPEARD, THEY FELL OUT OF THE SKY, MAY FRIENDS GAVE ME THE MEMORY, I DID A FAVOR FOR SOMEONE AND THEY DONT KNOW THE DIFFERANCE.
JUST BEWARE AND BECAREFUL THE ARE LOTS OF COMPUTER PEOPLE ALWAY WILLING TO HELP OTHER AT NO COST.
ROD IS THE CANDYMANGANDY
Acer TravelMate 6292 DVD not working
Click start control panel administrive tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver or select properties general troubleshoot
if your computer came with a motherboard disc the sound drivers could be on it
you might have to physically unplug the leads for this dvd rom restart your computer then plug them back in this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 03, 2011 | AGPtek Sony Optiarc AD-7560A CD DVD RW...
Bought a Sony optiarc AD-7261S, but have an IDE connection, so got a ADP-06 bridge board to connect the drive using my IDE cable. The Sony is the 2nd cd/dvd drive on this computer, and after plugging it...
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 30, 2011 | Sony NEC Optiarc Sony Optiarc...
I have an Optiarc DVD RW AD 7260S which was working fine. Now, however when I double click on the shortcut, it just ejects the cd and says that I need to insert a cd. Help pls
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 07, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
My Lenovo 3000 G410 Optiarc DVD RW AD-7560A ATA doesn't read dvd or cd anymore... so I can't install Ubuntu for my laptop. can you tell me what is the problem???
Did this just happen recently? Have you recently installed a new software in your computer? because sometimes when you installed a new software that is not compatible with the software installed in your computer conflict may arise and malfunction may follow but no worries there are a lot of trouble shooting steps you can do to fix this issue, you can either do system restore or delete the upper and lower filter in your computer.
To delete upper and lower filter follow the steps below:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
I hope this information will be helpful. Thank you for using FixYa!
Your Feedback is greatly appreciated.
Feb 25, 2011 | Sony Optiarc AD-7170S Burner
Tried uninsatlling and re-installing but dvd drive says unable to find driver code 10
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this dvd-rw burner then plug them back in this should activate the found new hardware wizard or
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 15, 2011 | Sony NEC Optiarc AD-7200S DVD-RW Burner
When i insert ant cd or dvd my pc hang and dvd drive shown in my computer (in windows) deleted. It again reappear after i again start windows after shutting down.
i dont quite understand but i think i get the gist of what you are saying
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 08, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
Optiarc DVD RW AD-7560A ATA Device NO FOUND
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 17, 2010 | Acer Aspire 5520-5156 Laptop
Code 10 driver won't start, recognize or run a disc.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 16, 2010 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
I have a Que!M3 60GB external hard drive. All of a sudden it is making clicking noises and is not recognized by my computer. Help! This has all of my pictures saved on it!
I assume that your operating system is on another hard drive. If so, try powering down your PC, disconnecting the external drive from the computer's USB port, powering back on and then connecting the drive to a different USB port.
If your computer still does not see the drive, I'm afraid the drive has failed. You might try taking the drive to a PC technician who may have utility software which will enable him to recover your pictures.
If you believe that this information was helpful to you please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Dec 10, 2010 | QPS Que! USB 2.0 Drive CD-RW Burner
CD Burner Does Not Work
Try a different make of disc, if same uninstal and re-install burning software. If you think the cd rom maybe has a driver problem, check this link to and try solution No.2 to try and solve. http://www.fixya.com/support/t126369-e_drive_wont_start_up_any_product
Dec 11, 2006 | E-Machines T2200 PC Desktop
Dell Dimension 4600 PC Desktop Logo
111 people viewed this question
Alun Cox
