Question about GPX ML648B MP3 Player
Won't work period
When I first got it it charged all the way. Now I can't get it to even turn on at all
  • 8,596 Answers
You will have to go to this website and download the GPX Software Restore Utility:
http://www.gpx.com/store/p/190-ML648B.aspx
-Tha Mp3 Doctor
Posted on Feb 15, 2009
Why won't battery charge?
The battery may need replacement despite the fact that your lawn mower is essentially new. Leaving it discharged for an extended period could have caused early failure. There is another possibility and that is the charger may have failed
Jul 16, 2013 | Worx 13Amp 16Inch Electric Lawn Mower...
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
Iphone won't start up
Un plug the battery check the connections on the battery and the iphone clean with some stochbrite and wipe off with 90% alcohol let dry and should work fine as long as the battery is fully charged.
Dec 26, 2012 | Apple iPhone 3G
2012 VW Jetta TDI battery won't hold charge and car only clicks and won't start
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
Oct 09, 2012 | 2012 Volkswagen Jetta TDI Sedan 2.0L...
I just bought the eclipse cld and it won't turn on after charging for hours
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Sep 30, 2012 | Eclipse Audio Players & Recorders
My Mintek portable DVD player's battery will not charge. I have rarely used the battery so I can't believe the battery is dead. The AC cord works to power it when plugged in. Why won't it...
After a while even rechargeable batteries loose the ability to hold a charge. This process accelerates when the battery is allowed to lie completely discharged for long periods of time. NiCad batteries especially have this issue. If you left the battery sitting for long periods without occasionally charging it, it losses the ability to hold a charge. It appears you are going to have to either do without the battery or replace the pack. I would take out the old one, it will eventually start to corrode and leak and if its still in your machine it will cause damage. If you get a new battery pack make sure you charge it fully and then depleat it completely before recharging it. hope this helps.
Jul 26, 2011 | Mintek MDP-1880 8.5 in. Portable DVD...
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Product: Innovage Digital Photo Keychain Issue: Not holding a charge In a nutshell, the hardware works (I've already used the minicd to load the software, and have even put pictures onto the...
What probably happened is the battery slowly drained on the shelf and its shot. Basically the type of battery in these (and a lot of other devices) can not be left with a very low charge for long periods of time or it degrades them. What happened is the battery just degraded and now cant hold a charge.
Jul 05, 2011 | Computers & Internet
Hi! I have a Nikon Coolpix. I haven't used it in a while. I charged it over night but it won't turn on.
Your batery is dead they don't like long period of staying discharging (If you 100% shure that your Nikon is working) The time of charge dosen't matter.
Jun 02, 2011 | Nikon Coolpix S210 Digital Camera
Has never charged, even after extended time periods - both with car charger and usb. Any tricks I'm missing. I've tried "ejecting" it but it just goes back to showing computer connection....
Sounds like the internal battery won't hold a charge and needs to be replaced. If you're "handy" you could do this yourself, but it's not for the faint of heart, and replacement batteries are available on the Internet. Here's a video that shows the procedure for disassembling and reassembling it to install the replacement: http://www.youtube.com/watch?v=PwAbKYOgiZg
May 11, 2011 | Garmin nuvi 255W GPS Receiver
GPX ML648B  MP3 Player Logo
91 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
