Question about Canon Office Equipment & Supplies
CANON S530D PRINTER NO BLACK PRINT ALL OTHER COLORS WORK
STOPPED PRINTING DUE TO PRINT HEAD FAILURE - REPLACED HEAD PRINTER PRINTS HOWEVER DOES NOT PRINT IN BLACK - I INSTALLED A NEW CARTRIDGE WITH THE SAME RESULT - PERFORMED CLEANING AN EXTENSIVE NOZZLE CLEANING ALSO USED THE SUGGESTED ON BOARD (PRINT DEVICE) BUTTONS FOR THE NOZZEL CLEANING TOO WITHOUT ANY CHANGE- ANY SUGGESTIONS my Cannon S530D printer doesnot print Black ink unless I am in easy photo print. Will not print a doc in black at all. I have changed print heads & even soaked the head with ink in it. nothing seams to work
5 Suggested Answers
jimmynuetron
  • 24 Answers
SOURCE: Missing Colors
This is a simple problem just reset your printer's color management settings!!!!!!!!!!!!!!!!!!!! :-)
Posted on Oct 24, 2007
SOURCE: HP K550 blak print failure
Hold the far button on the right down for a minute and it will move the head over for access
Posted on Jan 11, 2008
SOURCE: 3e Black cartridge won't print
I'm not an expert but I go through a lot of ink.. I have found that even with new ink some of the tanks of ink aren't any good especially with compatible which i buy a lot of because it's a lot cheaper (ebay). With that ink I have gone through 10 cartridges in a row before finding one that worked correctly again (I mean out of 100+ cartridges hitting a run of 10 that where bad but the rest good.)
Also, a tech for epson once told me to hit deep clean 7 times in a row before a head check to clean their nozzles.. That has helped with my printer and at Fry's electronics, they have a cleaning solvent in kit, haven't tried it, but i have run alcohol through mine but I'm told that is very ******* the print head (dissolves the glue).
Hope that helped..
Posted on Apr 03, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
SOURCE: Canon S530D-Have cleaned nozzles,changed ink
HI,
No I haven't fix the problem. However I've been doing all the cleaning,cleaning and more cleaning. I finally gave myself a x'mas present. I bought a new printhead for the S530D. It's working perfectly now. I was tossing whether to get a new IP4600 or a new head, finally decided on the latter. Simply I can't get after market cartridges for the IP4600. The cartridges for the IP were way too expensive at this moment and not knowing whether the claims for the print numbers are accurate. Perhaps readers may be able to collaborate the claims for the IP4600 or IP4500.
Regards and seasons greetings & a happy new year 2009,
yuen yoon
Posted on Dec 27, 2008
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Black color will not print. Installed a new black
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have set the Canon MP560 printer to print grayscale (black and white) but it still uses the color cartidges, apparently to periodically clean the nozzles so they will be able to print when needed. So I...
Canon has made there printer this way to SAVE on your black in and also to lubricate the print heads and other technical reasons.
To be honest I do not think its in your best interest to override the settings on this print due to the cause of damage to the print head and other sorts of failure.
There are chip re setters and other forms of ways to trick the system, These Void the warranty and thus Canon does not allow for this type of compromise to save ink. the best thing you can do here is purchase a ink kit with a chip that uses a contentious flo system to save you on ink purchases and money.
Here is a link to a example http://www.amazon.com/FantasyBuy-Bulk-Continuous-Ink-System/dp/B002T046TU
Good luck with your printer I hope this is a solution that best suites your needs to save money.
Nov 30, 2010 | Canon Office Equipment & Supplies
I've got a Canon Pixma MP 500. Printing from my computer = faded print. Copying = blank page. Auto head align fails. Alarm light goes on. Have tried stop/reset button. How can I fix this?
It sounds like the print head on your printer is either clogged or not working.
You get faint print from your computer because the computer will use your color inks to get gray. When you copy, it only tries to use black and the black isn't printing at all.
Check your user's manual and it should show you how to clean the print head. Otherwise replace the print heads and you should be fine.
Thanks,
Pat
Aug 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
My i560 Canon printer prints all colors but not the black ink
after a month of not using the printer, most probably the print head is clogged.. try using the printer utility to clean the print head.. it's under the printer properties.. normally that should resolve the print missing issue...unless your print head is really clogged up...
some would suggest to partial soak the print head onto warm water..but it doesn't work everytime..
May 24, 2010 | Canon BubbleJet i560 InkJet Printer
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
Only black!
The printer require print head repalcement.
Apr 18, 2008 | Canon BubbleJet i550 InkJet Printer
Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Apr 16, 2008 | Canon BubbleJet i560 InkJet Printer
283 people viewed this question
old marine
old marine
Corne Viljoen
