Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Clean front of Sub Zero
We have a black Sub Zero refrigerator (Model 550, circa 1990). The outside surface is some kind of plastic, I think...maybe glass, but I don't think so... We've taped things to the front of it over the years, but now we're selling the house and I need to clean it up. There's lots of residue from the tape left on it after I took all our little sayings and pictures down. Can you recommend something for cleaning it and removing this paint residue without damaging the surface?
  • sandyl808 Feb 13, 2009
    Thanks so much for taking the time to respond to my question!
    President:
  • 1,902 Answers
Try GOO Gone in either the liquid spray or the gel. This will not remove anything like paint or things like that. You can also use this on your cars finish and will not hurt it. So you are good to go
Posted on Feb 13, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 14, 2009
    No problem at all that is what we are here for. Thank you for using Fixya.com
Sub zero model 550 freezer not working
how old is it and is everything warm in freezer?
Jun 18, 2012 | Sub-Zero Bottom Freezer Refrigerator
Freezer reads 00 but the frig section reads 57....where is the line to the frig...seems that is plugged
i coud not see the model # of your sub zero . some models like th 550 / 650 use 2 compresors . freezer system maybe ok when fresh food is not . . first thing to do is ck the cond coil up on top and clean it and mk cure the fan is cooling the coil . you moy have a cold control failure . and the fresh food comp may be low on gas . these are the most common cause for your problem .. mm feed back pls ..
Oct 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have a Sub-Zero Model 550 whose freezer does not get very cold even though the set to 10
set freezer for 0 deg and clean the coils on top . and make sure the fan up top is working . very important .. mm 550 are r12 and may be low or refergent . this is somthing you may need a service tec to ck but do the cleaning first and see how it works. mm
Sep 03, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
Sub-zero refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
My sub zero model 561 dosent't cool when the weather outside is h
I had the same problem with my sub zero. I took off the grill on the top and vacuumed the coil that has the fan in front of it. The problem has not happened since. I'ts worth a try.
Apr 26, 2009 | Sub-Zero 561 / F
Sub-Zero 695s - plastic/rubber fridge door edge is warm
This is normal and is to keep door from getting moisture or sticking around door seal. You also can contact them at 1-800-222-7820
Sea Breeze
Mar 27, 2009 | Sub-Zero 695/O Side by Side Refrigerator
Sub Zero 550 series... The freezer door gets stuck and won't open. There's frozen condensation leaking.
The right side of the freezer has a drain that is plugged with ice. When the freezer defrosts the water runs down the inside of the box and onto the drawer rails, where it then freezes. The drain tube is normally kept ice free by an aluminum strap wrapped around the copper defrost tube in the freezer heat exchanger, which runs down into the drain tube. Over time the copper defrost tube gets some surface corrosion and the aluminum strap doesn't get warm enough during the defrost cycle to melt ice in the tube. If you can get it apart, you can clean up the tub surface with steel wool, or buy the electric defroster for the drain tube to replace the aluminum strap.
Sep 15, 2008 | Sub-Zero Refrigerators
Sub Zero model 550 bottom Freezer/ Refrigerator. The freezer section keeps freezing up and the drain off water runs down the inside across the rail frezing the door shut. No matter how many times we...
Clarkk I have seen this many times. Your drain is clogged. If you pull the drawers out and pull the top cover you will see the evap. On the cover you will find a nozzle that goes to the drain. Use some compressed air and blow out the drain. In some cases there will be some silicone that will need replaced. You can get a food grade silcone sealant at a hardware store. Hope this helps.
Aug 09, 2008 | Sub-Zero Refrigerators
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
130 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
