Question about Compaq Evo N610C Notebook
Kenwood dv-505 door will not open
The player turns on, searches for a disc, but will not open. Once the disc is in, it does work, but I can't get it to open to be able to insert a disc. The display window says "reading" then "no disc" and that's it.
  • rockfixya
    rockfixya May 11, 2010
    its a time to purchase new disc drive.......
    better then spand mony on old one.
    let me know for further assistance.
THERE IS AN EMERGENCY OPEN OPTION ON MOST ALL DISK DRIVES, LOOK RIGHT BELOW THE DRAWER USUALLY TO THE RIGHT FOR A SMALL PINHOLE. GET A PAPER CLIP AND STRAIGHTEN ONE END OUT, INSERT STRAIGHT INTO HOLE UINTIL YOU FEEL IT STOP AT THE MANUAL RELEASE CATCH AND GENTLY PRESS UNTIL YOU HEAR THE DRAWER BEGIN TO OPEN.
BLOW ANY DUST OUT, AND CHECK THE PC AND DRIVE WEBSITE FOR A POSSIBLE FLASH UPDATE FOR YOUR DRIVE MODEL. THEY ARE OFTEN POSTED WHEN DRIVES SHOW PROBLEMS READING SOME OF THE NEWER DISK BEING MADE. THIS HAS WORKED FOR ME A FEW TIMES IN THE PAST.
Posted on Feb 14, 2009
Kenwood dv-5700 stuck drawer
If the player is still under warranty "one year standard warranty" return it asp, this is probably a manufacture defect.
May 09, 2012 | Kenwood DV-5700 Multi-disc DVD Player
Stopped playing after I inserted damp CD in 200 disc loading mechanism
this can be due to some moisture in lens.
leave the unit to get dry for 2 days.
Jul 04, 2008 | Kenwood DV-5700 Multi-disc DVD Player
I asked for free help in ejecting my cd from my Kenwood DV-505. I have already reset the microchip to factory setting and have unplugged it for 5 minutes and then simultaneously held down the open/eject...
Normally on the drawer that you use to put in the CD there is a very tiny hole, look closely for it. Take a paperclip and straighten it out, insert it into the hole and push. This should help open the door. You might have to pull the drawer out the rest of the way but you should be able to get it out.
Nov 20, 2009 | Kenwood CD-403 5-Disc CD Changer
I have a kenwood dvd player
Are you sure it´s the laser the problem?
Because sometimes the motor disc spindle are the guilty of the failure of the dvd.Good luck
Jun 12, 2009 | Kenwood DV-505 Multi-disc DVD Player
DVD disappeared in DVD Player after viewing movie
Get the dummy cd disc, put a blue tac on it. Insert it. Then after few seconds, eject it. Your dvd disc should stick with it when they came out. It worked for me and hope it will work for you.
Jan 31, 2009 | Kenwood DV-505 Multi-disc DVD Player
Re: Kenwood DV 605 CD Player... Power On: Reads "Loading." All 5 CD lights are lit up but the CD changer does not turn. CD #1 appears on screen with two green lights appearing.
ace71cf.jpg We repaired this problem by taking the advice of another member of FixYa! The component had recently been packed to be shipped. After unpacking the unit when we powered up the read out only displayed "LOADING" and the CD changer door would not open. We removed the exterior cover and gently moved the CD changer one position. When it locked back into position we powered up and the unit works fine now. FixYa sure help me save perhaps a $100. or more by not sending it to the manufacturer or another shop. And it was working within minutes so we could enjoy using it right away. Thanks guys I very much will recommend this sevice to others... this was the 2nd problem we fixed that day by logging onto FixYa!!!
Z-Dawg
Dec 06, 2008 | Kenwood DV-605 Multi-disc DVD Player
Code for dvd player dvd252
Pioneer DVD player (DV-505, DV-525, DV-606, etc.) Note: Some codes work on LD/DVD combo players only, such as "Disc side A/B".
Note: The LD/DVD 0525 code will work too, but the arrow keys (among other things) won't work without being keymoved to the correct codes.
000 Chapter prev
002 Pause
003 Scan reverse
012 Disc side A/B
014 Random
028 Power on/off
029 Step/slow reverse
030 Audio
031 Exit?
033 Menu
034 +10
035 Power off
061 Power on
062 Power on
063 Demo (when player is off)
064 Power on
067 Reset (when player is off)
076 Program
077 Repeat A-B
078 Disc side B
080 Disc side A
082 Enter
084/086/088/090 Shuttle reverse
085/087/089/091 Shuttle forward
092 A/D/CX
093 8
097 9
140 Return
142 Last memory
143 Up arrow
147 Down arrow
150 Subtitle
156 Title
157 Mode (set-up)
158 Open/close
160 Angle
161 Condition
162 Step/slow forward
163 Chapter/time/frame search
191 Chapter next?
195 Chapter prev?
196 Right arrow
203 Left arrow
204 Repeat
205 Time search
208 Clear
209 Chapter search
211 Display
212/214/216/218 Jog reverse (w/still)
213/215/217/219 Jog forward (w/still)
220 4
221 0
222 6
223 2
224 5
225 1
226 7
227 3
252 Chapter next
253 Stop
254 Play (will turn on player and resume if player powered off)
255 Scan forward
Jul 11, 2008 | Televison & Video
Tray will not open on my dv-605
Solution: Unplug power from wall. (Don't just turn off!) Next: Remove exterior case. Now gently turn the CD changer clockwise one position. Power up and try again.
I had this same problem after unit appeared to have froze up when unpacked from a shipping box. The CD changer had got off track and by gently moving the CD changer 1 position it fixed the problem. Works fine now.
Best of luck,
Z-Dawg
Apr 30, 2008 | Kenwood DV-605 Multi-disc DVD Player
Dv-605 kenwood
I have a similar issue with my DV-605 as well. When the unit power on, I can hear the motor trying to start, but the DVD does not spin. Being the adventurous type, I opened the case and turned the DVD drive motor a few revolutions by hand and then the dvd played. I think I need a new DVD drive motor. You may as well....
Dec 09, 2007 | Kenwood DV-605 Multi-disc DVD Player
My Memorex DVD Recorder (MVDR 2102) won't open
Power is not turning on
was working until yesterday Jan. 8th 2009
Dec 06, 2007 | Kenwood DV-6050 Multi-disc DVD Player
Compaq Evo N610C Notebook Logo
57 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
