Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
Kenmore canister vac 25614
Power turns on for the beater bar with light on but no suction.  Removed wand , no power for floor mode(no suction).
    President:
  • 1,902 Answers
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Posted on Feb 13, 2009
Canister vacuum Sears model 116.59229210. The suction is coming through the vac for the hardwood floor setting, but the light on the power head will not work and the roller is not turning. I have...
Kenmore canisters are famous for melting the connection between the hose handle and the upper wand. They also sometimes melt between the lower wand and the power nozzle neck. Take it to your local vacuum repair center and get a diagnosis.
Dec 19, 2014 | Vacuums
Kenmore canister power head not working?
Without more info, I would investigate the drive belt, make sure the beater bar is free to spin (no hair or carpet fibers twisted onto the moving parts), and then check that the power is getting to the motor of the power head. Most often it is hair/fibers that collect around the ends of the beater bar. This causes the belt to stall, heat up and stretch due to the drive motor shaft spinning on one spot because the belt can't move. After removing twisted hair/fibers, you probably only need to replace the belt.
Aug 08, 2014 | Kenmore 25614 / 25615 Progressive Bagged...
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
Kenmore 25614/25615 Progressive bagged canister vac won't start
sounds like there was a loose connection or loose wire that came in contact with another wire. check your cord for small burn holes, also could have shorted out in the hose or the wand. If you are comfortable to disassemble the vacuum i can walk you through the troubleshooting process so we can find out what actually went bad. id start with the cord though. let me know if you have any questions or need more assistance
Jan 04, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
The vacuum works on carpet mode but not floor and only when the wand is attached to the floor brush otherwise it does not work at all
Please define "works" on carpet mode" do you mean when you say it does not work at all, that it does not run, or does not have suction.
This sounds like the symptom of a clogged hose with blockage like this another vac needs to be used to draw things back out of the hose the way they went in.. Remove the hose and try dropping a penny through it . If there is an obstruction the penny will stop at that point and rattle inside the hose.
With a blockage at the hose, your power head will still lift lint and light soft dust, it will appear to have suction because the brush will sweep but the dirt will not go all the way through the hose.
Please post back to clarify if this is a vac that does not run or simpley has no suction
Nov 04, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Height adjustment on power head
Generally, there are screws that hold the beater bar onto the vac head.  Loosen them, remove the glop that got in there and you should be okay.  If you remove the screws, note the location of all parts...Digital cameras are great things. If you forced the adjustment, you may have broken or bent something.
Nov 29, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Performance indicator light is on and suction is not strong
You do have a clog! trust me. Check the wand and the yoke which is on the brush assembly. its the part that connects with the wand.
if thats not it then it has to be in the hose. the only way to get it out of the hose is to take one or both ends off and push a broom stick through it
Feb 03, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
244 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
