Question about EuroTech EWC177 Front Load Washer / Dryer
Grey Stains on my whites
I have a top load Kenmore Washing Machine. My white sheets and shirts often come out with grey stains on them after the wash. What can I do? Do I need a new washing machine?
    President:
  • 1,902 Answers
Need ot check the main seal and the main bearing. You can do this by accessing the rear of the unit.
Posted on Feb 13, 2009
Kenmore top loading washing machine does not clean clothes well.
I would seriously consider getting a newer machine. A brown stain could be rust, or an oil leak. Either way it probably is not worth putting any money into. If this helps, please rate my answer. Thank you.
Jan 07, 2010 | Kenmore Washing Machines
White shirts have grayish stains
try soaking the shirt with ritz's white dye.
Sep 13, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I get grey stain/spots on my white cloths
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 09, 2009 | Kenmore HE2 Plus Front Load Washer
Round stains on clothing
Apr 11, 2009 | Kenmore 5.7 cu. ft. Coin Operated Electric...
WASHING MACHINE CAUSING GREY STAINS
Mar 04, 2009 | Washing Machines
My whites are not comming clean and are not a bright white
I don't know if this is a solution to your particular problem but when we wash whites, first, we wash them twice,with hot water, second, we dont use bleach!!! (this will eventually yellow them). Third, we dont use liquid softner. For the whites we use a softner sheet in the dryer. Since we started to use this procedure I have noticed a marked decrease in areas such as under arm stains in white under shirts. I have some that are 2 years old and have no stains or yellowing like this. Hope this helps
Jan 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Old washing machine is starting to leave grey streaks on clothing
hmmm..let's see..sounds like you have some residue accumulating from something possibly seeping into the tub. That can be old rubber, a metal sheath, or even an leak of lubricant. Like an old car, there are parts of every mechanical device that need to be attended to.
I'd recommend you find the most seasoned person that works on older machines, to come by and assess what is 'leaking' on your clothing. Grey comes from something metallic or rubber/plastic.
Hope you can solve this one, and keep that old machine happy.
Feb 19, 2008 | Washing Machines
Miele W1119 not cleaning white clothes properly
liquid detergent is a pain and not as good as powder. liquid detergent often makes machine smell as well i doubt there is a fault with the machine. try putting on a boil wash with no clothes and this will clear out the slime left behind by the liquid detergent. you didn't say what colour the stains are but iy grey or brown it could be from your water supply - a more common problem than you might think. turn off water and remove the supply hose. there should be a gauze filter at one end and make sure not clogged with dirt. also look into the spigot of the vavle and see if any muck there.
May 11, 2007 | Miele Touchtronic W1119 Large Capacity...
EuroTech EWC177 Front Load Washer / Dryer Logo
302 people viewed this question
Top EuroTech Washing Machines Experts
shaun taylor
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
