Question about GE Dryers
Attaching Power Cable
Didn' pay attention when I took old power cord off my old dyer when moving people took it. Now I'm not sure witch wire up to the red, black and white terminals in the dyer. I have a 3 wire power cable with a 3EMA L6-30P (3) prong plug with 2 staight male connectors at angle and one L shaped male connector above them. I'm not sure which wires to hook up to the different colored wires in the dyer. Thanks for any help you can give me. I do have a multimeter by the way.
    President:
  • 1,214 Answers
The two outside wires of the flat power cable are the power wires. The middle wire is neutral or ground.
Hook one of the red outside wires to the red, the other to the black, and the center one to white.
Posted on Feb 13, 2009
I HAVE A MAYTAG LAGACY AND IS TO HOT , TWO DAYS EGO I CHANGE THE CABLE OF THREE FOR ONE OF 4 AND THE RED CABLE IS IN THE RED CABLE OF THE DRYER AND THE BLACK CABLE IS THE BLACK CABLE OF THE DRYER THIS CAN...
Double check your power cord installation. The following link explains in detial how a power cord is to be installed and the differences between the 3 and 4 wire configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
There is a difference in how the power cords are installed. Pay particular attention to how you have the ground and neutral wires terminated. If installed incorrectly, the dryer may not run, you could damage the appliance, or you could create an electric shock hazard. If you have questions, please post back and let me know. I hope this helps you.
Mar 14, 2011 | Maytag Dryers
We just moved and this house has a 4 prong dryer plug and our last house had a 3 prong dryer plug. We bought a new plug and hooked it up as it says and still nothing. Any help would be much appreciated!
You may have inadvertently incorrectly wired the dryer power cord. The following link epxlains the differences between the 3-wire and 4-wire configurations:
Make sure you have the wires connected properly at the terminal block. Pay particular attention to the difference in how the ground and neutral wires are connected. If you have any questions, please post back and let me know. I hope this helps you.
Dec 01, 2010 | Roper REX4634KQ Electric Dryer
How do i hook up a different electrical cord on a maytag LDE712
The following link explains how to correctly install a power cord to your dryer:
There is a difference in how to terminate the connections on a 3-prong and a 4-prong power cord. Pay particular attention to this and make sure you match the corresponding wires correctly. If your wires are not color coded, the outer two wires on the power cord (left and right) are the HOT leads. The center conductor is the neutral.
If you have any questions about this repair, please post back and let me know. I hop this helps you.
Mar 29, 2010 | Dryers
Maytag electrical dryer model # PAV2300AWW power supply layout
The following link explains how to properly connect the power cord to your dryer:
Pay particular attention to WHICH configuration you have. Your power cord will either be a 3-wire or 4-wire configuration. NOTE: If the wires are not color coded, the outer two wires (left and right) will be the HOT leads. The center conductor is the neutral.
If you're new home is equipped with a 4-wire outlet, you are required to update the dryer to a 4-prong power cord to be in compliance with the National Electic Code.
Mar 27, 2010 | Maytag PYE2300AY Electric Dryer
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
Need to put plug back on and don't know which prong goes to what wire
If this is for United States standard wiring the following link explains how to properly install a power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have questions, please let me know. I hope this helps you.
NOTE: Make sure you pay particular attention to the differences between a 3 and 4 prong wire configuration. It does make a difference how these wires are installed. If you're not sure, ask me.
Jul 07, 2009 | Dryers
HAD TO CHANGE FROM 4 PRONG TO 3 PRONG AND NOW DRYER RUNS FOR A
When you connected the new cord, did you make certain to connect the line 1/2 wires to the Line1/2 input's, and the Neutral to Neutral inside the wiring compartment?
Not heating up almost sounds like the heating elements are not getting their full 220 VAC, but then if you had something wired wrong in back, a breaker should trip. Make sure you've connected the new power cord correctly at the input power point. I am guessing this problem occurred between the time that you had it at the old house, and the new house, with the power cord changeover.
Jan 22, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Prongs on dryer
Take old cord off. Remove wire or ground strap connecting dyer frame to center (nutral) terminal. White wire goes to center terminal. Green wire to frame (ground) Red and Black wires go to two remaining terminal, order really won't matter.
Sep 28, 2008 | Whirlpool LER5636P Electric Dryer
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
Dryers Logo
Top GE Dryers Experts
Richard Roth
Richard Roth
Melissa Martin
Melissa Martin
ancel1961
Level 1 Expert
Are you a GE Dryer Expert? Answer questions, earn points and help others
