Just got this used rca hdtv model number D52W17 plug in my digital cable with the red, white, blue, green red, on both ends into component one and component two trying them both the picture shows up in 3 identical split screens rather then one large picture as it should...i've tried going thru the menu options on the tv but nothing i try changing seems to make any difference.
SOURCE: RED GREEN BLUE CONVERGENCE IS OUT.
What is your Chassis # ? And convergence problems can be some of the most hard to realign. You may need to replace amps.
SOURCE: distorted picture on RCA LCD TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part # 259638 search the web for the part.
SOURCE: My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
SOURCE: Warped Picture & color alignment
This is a convergence problem. I had a similar set recently that was fixed by resoldering poor connections at the flyback transformer and replacing a blown pico fuse located there as well. I will look up my records to get the specific fuse location and post later.
Dan
Testimonial: "good information - RCA no longer supports the picture tubes and have discontinued this model as well. "
