Question about Maytag Neptune MAH5500B Front Load Washer
Bleach wont drain during washing
I have a maytag neptune mah5500bww washing machine and the bleach tray wont empty during washing
  • Anonymous Mar 19, 2014
    the bleach releases during the next load
    President:
  • 1,902 Answers
You may have a clog on that side where the water comes into it, or the dispenser valve is not opening that side.
There is a service sheet inside the bottom of that front lower access panel on the right side wall, you can go through the diagnostics to test the water flow to that side of the tray.
Posted on Feb 13, 2009
I have a Maytag Neptune 1st Generation and the washer door gasket always molds, how to clean and how to prevent molding
The Maytag MAH300AWW was the first generation front load washer. Your MAH5500BWW is a much newer version and has a boot drain and door venting to minimize the mold. Just be sure your drain (bottom center of the boot) is clear. Use a solution of 1/2 cup of Granular Dishwashing Detergant and 1 cup of Chlorine Bleach added directly into the tub. Run the machine through a hot was cycle (with NO clothes inside) every few months and this will reduce or eliminate the mold.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
MASHER MAH5500BWW WONT DRAIN
this unit has a electric drain moter open the machine front . under the tub remove the drain hose and look for the a blockage if none present replace the whole drain pump assembly
Jul 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG NEPTUNE FRONT LOAD WASHER MAH5500BWW
Central bearing and seal are damaged. Very expensive repair and very expensive parts. Maytag does not sell bearings separately, they're only available with the outer tub, which is $400-$500; Repair itself is another 2-3 hours of hard work. Do the math...
Jan 02, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
274 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
