Question about SanDisk Sansa e260 MP3 Player
My Sansa e260 won't recognise a 4gig micro card.
I've formatted the Sansa and updated the firmware but still no joy.
Can anybody help please?
Thank you,
Graham.
  • redundancypa Feb 13, 2009
    Wow, that was quick response, thank you.
    The micro sd card is working fine, I've put music onto it via the computer. I did format the card first.
    Best regards,
    Graham.
  • rockfixya
    rockfixya May 11, 2010
    1. check the memory card is working or not.
    2. if memory card is working then format it using a card reader.
    let me know for further assistance.
    Thanks
  • 679 Answers
Ok...
Try formating the card using your sansa, so it helps to transfer sansa system files to the card.
please post back reply for further assistance.
thanks
rock
Posted on Feb 13, 2009
  • 21 Answers
There are two types of 4gig micro sd,
theres MicroSDHC For nokia phones or
MicroSD Standard
The HC have a file format on them that only Nokias and Samsungs tend to recognise for mobile data transfer and access. The standard cards don't.
Hope this helps
Alen Boardman
Ive a e260 v2 . which ive had since 2009. I was very pleased with the player Someone said the other week that i should Update the Firmware . So i did download the firmware search and it uploaded it,...
Hi, it might not be from the firmware update that the volume gets low.It might be from the speaker already getting bad without you noticing it. you can replace the speaker too it might work out.
Also firmware update can cause it too. Updating with the wrong firmware ...
You can use the below link to know the right firmware update to use for you san disk sansa e260 mp3 player..e200 might work with yours..
kb.sandisk.com/app/answers/detail/a_id/156/kw/firmware/r_id/101834
1. Download the SANSA Updater from:
sandisk.com/sandisk-support/driver-download-wizard.aspx
2. Install Updater
3. Plug in the SANSA e260
4. If it needs new firmware, it will tell you to download and install.
5. Follow directions on screen.
Hope it helped.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e260 MP3 Player
I need to know the maximum GB external micro sd card I can put in a sansa E260 4 GB Mp3 player and a sansa express 1gb mp3 Player.
thank you for choosing Fixya.com
you can use 4GB it is the applicable memory on your mp3.
if you will try to use much higher than 4gb sometimes it is the reason why our player are hanging up.
please don't forget to rate our answers properly.
Mar 05, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
Dec 01, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Sep 02, 2008 | SanDisk Sansa e260 MP3 Player
PC cannot detect Sansa e260
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 20, 2008 | SanDisk Sansa e260 MP3 Player
SANSA e260 will no longer get further than 25% of refresh database & freezes
I would recommend that you update the firmware on the device..Once the firmware is updated you shouldnt have that problem anymore..I hope that helps
Thank you
COmputerrep
Mar 17, 2008 | SanDisk Sansa e260 MP3 Player
Sansa
I would recomend you to get a firmware upgrade done on your device..call sandisk and tell them you need to get a firmware update for your device...
Jan 25, 2008 | SanDisk Sansa e260 MP3 Player
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Problem With Format
Hi, you may want to try using the manufactures preferred method or better still update the firmware. It is available at http://www.sandisk.com/Retail/Default.aspx?CatID=1376. Please let me know if this woprks out ok with your Sansa e260. Regards
Apr 09, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
144 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
