Question about Crosley CDE6000 Electric Dryer
Dryer will not heat
I have checked the element and therostats they seem fine what else should I check?
  • Anonymous Apr 11, 2009
    the dryer is pilot less and i dont know how it works it doesnt heat
    President:
  • 1,902 Answers
Could be a number of things. Here's how a dryer works during an automatic cycle:
* The cycling thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--at least 135 degrees.
* When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
* The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
* This cycle continues until the clothes are dry.
If the vent system is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork. A dead ringer for this problem is if you see that the timer is advancing but is doing so too slowly or stops mid-cycle and doesn't go any further. It normally takes from 45 minutes to an hour to dry a load of clothes on the automatic cycle. Sounds like you already cleaned the lint system, so let's go on.
Check and make sure the vent duct hose is not restricted in some way. A dryer only dries as fast as air can flow through it, even if the heating element works. O.k., next...
You could have a bad cycling thermostat. A dryer usually has two thermostats. One of them is mounted to the internal duct system by two screws and has two wires. THIS is the cycling thermostat. One of the wires goes to the timer to tell it when to advance, and the other wire goes to the other thermostat (the high-limit thermostat), which is mounted to the heating element housing, to tell it when to cut the element on or off. If the high-limit thermostat is bad, then the heating element will usually either not come on at all or will stay on all the time and overheat, which may throw a thermal fuse if your model has one. (A bad cycling thermostat can also cause overheating.) On some dryer models, the dryer will not come on at all once a thermal fuse has blown. The high-limit thermostat or thermal fuse do not seem to be your problem, though, since you say the element is working.
The Cycling Thermostat can be tested with a multimeter, or you can just replace it in most instances for $18.00 to $30.00, depending on your dryer model. BEFORE TESTING THE THERMOSTAT, UNPLUG THE DRYER!! To test the thermostats or fuse, set the multitester to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Hope this helps. It's not as complicated as it sounds.
Also check and make sure that your vent rap and vent lines are clear and not crushed
Posted on Feb 13, 2009
    Genius:
  • 2,920 Answers
The limit switches are known to go bad on dryers
Dryer not heating
Did you check to see if the new heating element is receiving power? If no power, did you check the switch that feeds the element?
Oct 20, 2015 | Dryers
Dryer does not heat. Motor and fan work fine.
is there a reset button on your element that needs to be pressed in have you checked the voltage going to element might be pc.board
Apr 05, 2014 | Samsung DV210AEW Sensor Dry Electric Dryer...
Dryer works fine except it does not seem to heat properly. Wondering how the element is installed and where I could find replacement heating element.
I would need a model number to look up your heating element.
I can tell you that chances are if the dryer heats, but just takes to long to get things dry the heating element is probably ok.
Poor air flow is what causes dryer to take longer then normal to dry.
You will want to check your vent for restrictions such as kinks or lint build up. Don't forget to check the outside hood as it has a flapper or even a screen that can catch lint.
If your vent is ok then you need to take the dryer apart and check for lint build up around the blower housing and fan.
Aug 02, 2011 | Dryers
Dryer is not heating up.
90% of electric dryers emitting cold air need a new heating element installed. If you've checked the thermal fuse, and verified the unit has around 220 volts of power, then the only thing left is the heating element. Typically costs around $40-$60. Can be done by you if you have basic electrical knowledge, otherwise call an electrician.
May 13, 2010 | Kenmore 62802 Electric Dryer
The dryer runs fine but produces no heat. Multimeter readings at the heating element seem normal.
check the cycling switch,the hi-limit switch and the cutout switch all located on or near the element case,all items have control over the elements heating or the complete shut down of the element to prevent fire
Feb 01, 2010 | Dryers
Dryer won't heat---seems to work fine, but no heat. Removed the back panel, but not sure what I'm looking for...HELP!!
From the way you describe it, sounds like the heating element is gone. It is located under the silver tube under the back cover.
Check to make sure there are no breaks in the element.
The element looks like a big long spring..
Jun 04, 2009 | Dryers
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Kenmore ultra fabric care dryer runs, but does not heat up
check the thermal fuse the operating therostat and the igniter is this a gas or electric dryer
Jan 12, 2008 | Kenmore 62602 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
264 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
