HP Pavillion dv9700 won't power up
Hi, my HP Pavillion dv9700 won't do anything. When i press the power button the blue keyboard lights at the top come on, the hard drive sort of clicks a couple of times (electrical clicking because the drive doesn't spin) then the lights go out and thats it, Can anybody help please. Thanks.
  • 2 more comments
  • msaint Feb 13, 2009
    Tried the solution, nothing. Its like there is no power getting to any of the components. The are no beeps or anything when i turn on the computer. Thr blue lights come on for a secnd then offthey go. No disk r fan sounds. Nothing on screen at all. The power supply is fine and so is the battery. Tried them on another compute and they we fine. hnks for the quick reply by the way.
  • akhtersuhail Apr 11, 2009
    pavillion dv9700 won't power up. All blue lights come on. get blank screen. there is no error code from the mother(no flashing caps/numlock light), indicator light won't turn on when pressing caps/numlock keys. computer restarts if left alone for 4-5 minutes. tried discharge by removing battery and pressing power button. reseated memory.
  • Holdfast4 Apr 26, 2009
    my dv9700 went dead suddenly and now will not power up at all. The AC light is on but no other sign of life. I tried removing the battery, reseating the RAM and holding down the power button for a full minute. I've read perhaps this could be due to an nvidia card problem.
  • rockfixya
    rockfixya May 11, 2010
    is there any beep sound.. when you turn on the computer?
  • 1,602 Answers
TRY HOLDING DOWN F10, F12 BEFORE YOU TURN ON THE SYSTEM, WE ARE TRYING TO GET IN THE SAFE MODE TO CONTINUE IN WINDOWS TROUBLE SHOOTING GUIDE, REMOVER THE BATTERIES AND UNPLUG THE SYSTEM TO FORCE IT TO TURN ON IN SAFE MODE THAN SELECT THE ONE MOST LIKELY SOUND WHICH ONE WILL DO THE BEST JOB FOR THE BANG.
Posted on Feb 13, 2009
I tried the solution #1 and it works for me. However before of that I take out the flat battery from the motherboard, the power cord, and the rechargable battery for almost 2 minutes and when I put all back again I tried the solution #1 recommended by HP Pavillion dv9700 won't power up - noavatar_s.gif RODGANDYSR and it works. I recommend to do the same for those who have this problem.
Posted on Jun 09, 2010
  • Kurt Sather Nov 28, 2011
    I tried this for my problem and did not fix my particular issue. Thrilled it helped you though!
2 Suggested Answers
Morikvendi
  • 56 Answers
SOURCE: HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Posted on Jun 01, 2009
HP Pavillion dv9700 will turn on but the hard drive light will not blink and the screen is blank
You may be able to rescue it with a Bios flash, but it sounds like your motherboard died.
Jun 30, 2012 | HP Computers & Internet
HP Pavillion dv9700 does not power on
It would seem that the power button is faulty, usually, this is because one or more of the four solder connections by which the switch is attached to the printed circuit has become detached, sometimes caused by pressing it too hard. Rectifying this is quite an intricate job requiring a lot of disassembly and skilled soldering. If you are in any doubt take it to a professional.
Apr 07, 2017 | Computers & Internet
My hp pavilion dv6000 touch pad locked up, it no longer responds.
Try pressing the button above the touchpad to make the light blue, that should re-enable the touchpad again.
Regards.
Jan 13, 2011 | HP Computers & Internet
Laptop is not working
the only possable problem is the power source. so most likely your power converter box on the power cord has over heated, which is common, its expensive to replace though($70-85). if the problem continues take it to a shop don't try to repair the internal power converter yourself.
Nov 16, 2009 | Compaq Laptop Keyboard for HP Pavilion...
I have an HP Pavilion 9000 that was working just fine. We powered it down for the day and when we went to start it up the next day it would not start. Blue light is lit where power supply plugs into...
That a nice computer you have there. Based on your description, my guess is you have a bad power supply.
About a $300 fix if you send back to HP. Which is what I had to do a while back.
Oct 20, 2009 | Compaq Laptop Keyboard for HP Pavilion...
No power from cord to computer
Hi...
If your laptop is under warranty go back to the manufacturer. If not go to hp center and buy a power cord of your charger which is totally fix to the charging hole.
Good luck
Regards
PCmania
Sep 25, 2009 | HP Pavilion dv9000z Notebook
I need to know where the wireless switch is on an HP Pavilion ZV5410US laptop computer
Most HP Notebook PCs have wireless devices built-in. To turn on the built-in device, simply press the wireless power button on your PC which will have the universal symbol for Wi-Fi (shown here on the left) and illuminate with a blue light.
Sep 03, 2009 | HP Pavilion zv5410US Notebook
My hp pavillion will not power all the way up
What do you mean it powered on to the blue light?
Does anything show up on the screen?
Does the system usually beep when it starts? If so, does it beep now?
Jun 16, 2009 | Computers & Internet
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
Computers & Internet Logo
7,878 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
