Question about Singer 5050 Mechanical Sewing Machine
Bobbin thread will not catch
How do re-time a sewing mach.?
  • helmfamily3 Feb 15, 2009
    I have the same problem with my Singer 7412. The bobbin thread will not catch....I have worked on it for several hours and cant figure out the problem. Please help asap. Thank you
    Problem Solver:
  • 6 Answers
This is really one for an engineer. It involves loosening the bobbin race and moving it slightly till the hook catches the thread,and then retightening. Can be an awkward job requiring 3 hands,even for an expert!
Posted on Feb 21, 2009
My bottom thread wont pull out once the cover is closed and the thread is pulled through and ready to sew.
If the top thread is not pulling up the bobbin thread, is it actually catching the bobbin thread? If not, then the machine may be out of time. Search for sewing machine timing or take it for service.
If it catches the bobbin thread but then the bobbin thread is difficult to pull, then possibly there is a snag somewhere that is catching the bobbin thread, the bobbin tension needs adjustment, or the bobbin case is incorrectly threaded.
Nov 01, 2017 | Sewing Machines
My thread is not catching with bobbin thread
Be sure to use a brand new needle. A bent/damaged needle may not connect with the bobbin thread.
If it still does not pick up the bobbin thread, your machine most likely has a timing issue (the needle arrives at the wrong time to intercept the bobbin thread). There are multiple web sites and videos that discuss sewing machine timing. Or take it for service.
Sep 30, 2016 | Sewing Machines
Singer sewing machine will not catch bobbin thread to sew
Check the bobbin tension and timing. Please top and bobbin using to new quality threads.
Dec 29, 2013 | Singer Sewing Machines
I have a Pixie sewing machine that will not sew. It appears that top thread is not connecting with bobbin thread. When I just slowly turn the hand wheel I am hearing a little snap and I feel a little...
If you are sure that you are using the correct needles and they are
correctly inserted, have the timing of the bobbin case checked on your
machine.
Feb 23, 2011 | Singer Sewing Machines
The main thread is not catching the bobbin thread
It looks like your timing of your bobbin hook is out you will need to have a service man adjust it for you.
May 05, 2010 | Sewing Machines
Bobbin case catching-tangling thread
It sounds to me that you might have the wrong type of bobbin in the case. The top of the bobbin should not be higher than the case. Thread will slip through the space and cause problems. Also unevenly wound bobbins will also cause this symptom.
Or your losing tension which you will have to adjust tighter.
Jul 23, 2008 | Singer 3116 Simple
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Singer 5050 Mechanical Sewing Machine Logo
97 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
