I turned the knob it felt tight and when i put the stove on high it stayed on high i could not adjust it to med, or low now it wont even turn off when i tried turning off the stove it continued to burn what can i do i tried removing the front panel to the knobs but the line is connected to all the other knobs help!
SOURCE: Burners - Oven not working
thanks reg501...
after inspecting our plug where it connects to the stove, i noticed the neutral was loose. everythings working for now. i am a little worried though, where the black wire connects to the stove, it shows signs of getting hot. im guessing this was where it wasnt properly grounded...
thanks again, the wife is very happy now...
SOURCE: Light indicator when burner is turned on will not shut off.
if there is one light for all the switches, you will need to unplug the unit, take off the top part of the back panel to get access to your switches. the indicator light is run to all 4 switches. you will need to unplug the wire that goes to the indicator light from each switch ( only one at a time ) and plug the unit back in each time. do this for every switch until the light goes out. whichever switch has the indicator light wire removed from it when the light goes out is the switch that needs to be replaced. if your unit has an indicator light for each switch, then just replace the switch that is above the indicator light. Joe
SOURCE: Maytag Gemini gas stove top ... while starting one
You have a gas leak which resulted in the unwanted fire. This has the potential to be serious or deadly. This is one time when you need to get a pro in there to stop this leak and get your stove safe again.
SOURCE: I have a gas range and I think the burners are
ther should be 2 sets of brass nozzles for the burners, make sure that the correct ones are installed, ie natural gas or propane. they have a different injector size for each.
SOURCE: where can I go and get directions on how to
Good afternoon. We are Maytag factory authorized service and parts suppliers and have all the solutions for your Maytag appliance issues.
We have the proper element for this model and can get it out to you asap.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST and we will get your parts out right away.
We look forward to hearing from you. Thanks, Ella
