Question about Sharp AR 201 Copier
SHARP AR201 COPIER
MY COPIES ARE COMING OUT WITH A LIGHT GHOSTING BACKGROUND IMAGE AND NOW A 1 INCH LIGHTER STRIP RUNNING DOWN THE MIDDLE RIGHT SIDE OF THE PAGE. WHAT PART NEEDS ADJUSTING OR REPLACING. WHAT IS THE FASTEST WAY TO FIX.
THANKS, ROBERT
    Sergeant:
    Champion:
  • 237 Answers
Hey Robert,
Sounds like it could be in need of a maintenece kit. The ghostinf is usually caused from the fuser or transfer roller. And that would also apply to the band down the page.
Posted on Feb 13, 2009
All my 8-1/2" x 11" copies are deeply streaked
Chang your UHR and LHR with stripper fingeres, if it is not available at your country change the fusr unit it will resolve your problem feel free to contact me if you have any difficulties and rate me
May 03, 2011 | Sharp Office Equipment & Supplies
Copies paper great except leaves a long invisible 1 inch thick line down the middle
You can try to clean the scanner light, but the light does not cast a straight one directional beam. It is more like a flood light, if one spot is blocked it will still cast light on that spot of the paper.
Try checking the print cartridge. Normally if it is an inkjet copier, it will leave a line in one spot if there is a defect in the cartridge or if it is running low on ink.
I woul try another cartridge first, then we can go from there.
Feb 13, 2008 | Canon PC1061 Copier
What causes a line down the middle of copied pages
There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on.
May 24, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
May 20, 2010 | Office Equipment & Supplies
Sharp AL 1631 Grayscale Copier Placement of Shutter Film strip
you may have removed the toner receiver strip.you have to removed the drum from the assembly.you can remedy that with .5 inch masking tape.
Jun 09, 2009 | Sharp AL 1631 Copier
Print quality
Ghosting can :
1-prints on the fuser roller, check if yes try cleaning it off, wait until it cools off
2-blanking lamps dirty or not working,(deletes image off the drum, before it gets ready to accept a new one)
BL mirror-(new image)
drum
3-Bad drum (although I doubt it this far in the process.)
Sep 05, 2008 | Ricoh Aficio 1013F Copier
Sharp ar-m237 copier
Direct light can effect the copies. Your unit may also need developer as well. If the developer is low or gone out of the unit, light copies will appear as well.
Jul 10, 2008 | Sharp AR-M237 Copier
Displays E7. Meaning? Fix?
That has to do with the laser unit and/or the white shading plate.
First remove the platen glass and clean the white strip on the bottom side. BE CAREFUL FOR THE GRAY OR BLACK LINE ON THE STRIPE IF YOU WIPE IT WITH A SOLVENT AND REMOVE THE LINE YOU ARE DONE.
If the unit is making a whining noise it is probably the laser unit polygon motor.
Apr 28, 2008 | Sharp AR 201 Copier
AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
Sharp AR 201 Copier Logo
157 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
