Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Odor from outside of Refrigerator
Refrigerator is emitting a fishy or antifreeze kind of smell. The insides have been completely cleaned with bleach yesterday so the odor has to be coming from the back of the unit. What could be the problem? Thanks
  • 1 more comment
  • mclean79873 Feb 13, 2009
    The inside of the refrigerator and top freezer did have the odor before we cleaned it out entirely with bleach. We had tried 409 etc but the odor returned. No, there was not any spoiled food or cheese, and has not been turned off. The food still seems to be cold enough and ice is frozen. This has been going on for about a week. Thanks
  • Mark Egan May 11, 2010
    Put a new, opened box of baking soda in the refrigerator for a week. Try not to be too "nosey" to see if you can smell odors.
    Smell again after a week has passed to see if the odor has reduced any.
    There is not a path between the inside and outside of the refrigerator or freezer sections, other than to allow refrigerant and water lines to pass through. Odors are pretty confined to what has been in the freezer or refrigerator, unless a critter has crawled in there (but critter normally get in the food, not the freezer or behind the freezer panel/plate.).You can try and remove the back plate in the freezer section to check for mold growth, but normally that is not a problem in freezers. You can also check the drain tray which drains the accumulated water that is the result of melted frost from the defrost cycle.
    Always clean a refrigerator or freezer with warm water and baking soda.
    Is the odor coming from inside or outside of the refrigerator? Do you smell it on the freezer side?
    Has any food spoiled or soured in the refrigerator or freezer sections while the unit was turned off and the doors closed?
    Reply back and we can help you further.
  • 135 Answers
Pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. We have seen this before. Hope this helps!
Posted on Feb 16, 2009
How do I get rid of this terrible fishy smell from my freezer/refrigerator?
Hello Heather.
Have you had anything wrong with fridge that caused the smell.
Try charcoal in both fridge and freezer.
Hope it will help.
Fish smell is hard to get read off
May 21, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Why is my GE Monogram, model zfsb26dnd SS, emitting an odor from the front bottom behind the base grill. The air blowing from underneath produces the smell when the fan is operating. The odor appears
If your refrigerator is frost-free, check the drainage tray at the bottom, probably behind a removeable grille. You may find the tray is full of all kinds of disgusting stuff collected by drainage during defrost cycles. Remove the tray and clean it thoroughly. Reinstall the clean tray.
Dec 10, 2014 | GE Refrigerators
SQD26VL side-by-side has a fishy odor. Where is drip pan?
The drip pan is outside the fridge I believe, sitting in the back panel.
Apr 27, 2012 | Amana 22.6 cu. ft. Side-By-Side...
We have got a hotpoint future fridge and we have
after you have cleaned the refrigerator, place a small bag of open charcoal in the freezer section and refrigerator section until the smell goes away.
Jul 24, 2010 | Hotpoint HSS25GFP Side by Side...
Odor problem in refrigerator section. Have thoroughly cleaned but odor is still there. Refrigerator is a Kenmore elite cold spot purchased 3-4 years ago. It is a 2 door with exterior ice and water.
clean out drain holes with clorine bleach(do not use to clean inside unit)poss smell stale wet carpet ???
black gunge is streptococus.....grow your own penn...
Feb 11, 2010 | Refrigerators
My older KA Ref Model KTRP20K & M is giving off a strong odor similar to iodine. Very strong in AM but can still smell it in PM. I've checked for spoilage and nothing there. Any thoughts? Is it time...
since it is working ok . i am wondering if you dont have mold growing in the drip pan ... condensation from inside the refrigerator goes down a small tube in the back bottom of the frig ... that tube goes to a pan under the refrigerator and normally the water just evaporates .. if there is a lot of condensate from the frig then the pan may stay wet long enough for mold to get established ... a large amount of condensate from the frig usually indicates a leaky seal around the door .. or a door that doesnt close completely .. you might want to clean everything under the frig including any fans, coils and that pan (unplug first) ... now this all assumes that the smell is coming from the outside not inside the refrigerator .. if the smell is inside then you may have to defrost and clean the evaporator (the coils inside the freezer (somtimes also in the refrigerator) ... there are some kinds of mold that actually grow in that cold environment .. some hot soapy water with a little bleach usually does the job .. or if you have one, a steam cleaner, those do great .. it allows you to get down in the little places and clean everything ... make sure the frig is at room temp first so plastic doesnt crack ..
the refrigerant r22 or r134a have very little smell so even if you had a leak it wouldnt smell strong .. a few refrigerators use ammonia and that would have a distinctive smell easily recognized if there was a leak .
Nov 22, 2009 | Cell Phones
Fishy smell in camper fridge
They freon used is mainly amonia,best thing to use is bleach put in spray bottle mix 70 percent water and 30 percent bleach squirt entire fridge let soak then wipe clean let air out as much as possible!!!! :)
Jul 19, 2009 | Zanussi ZEBF277W Bottom Freezer...
Our Kenmore Coldspot has an awful odor whenever you open the door
use straight bleach on it. sponge down the whole inside with bleach and if you can leave the doors open on it to let it breathe and clear the odor out. bleach kills most smells if left on for awhile.go over it a couple of times if you have to to get rid of the smell.
Jan 17, 2009 | Kenmore Refrigerators
Refrigerator Smell
remove grill. pan will not come out ( leave it in place ) took an empty liquid dish detergent botlle of bleach and water squirt into pan let it sit - scape if needed . then take a wet/dry vac - repeat)
I will let you now if the odor is completely gone
Oct 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
583 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
