Question about HP LaserJet 3330 All-In-One Printer
I need to get a copy of a document that I faxed.
I faxed a document thru my HP LaserJet 3330 and did not receive a confirmation sheet. I was able to print the Fax Activity Log and saw that the fax was successfully sent. Is there a way to extract a copy of the document I faxed displaying the date, time, and fax number I faxed it to on the document copy itself?
  • 23 Answers
This might be what you are wanting. Hope it helps.
Including the first page of each fax on the fax call report
If this option is turned on, the fax call report will display a thumbnail (50% reduction) of the first
page of the last fax that was sent or received.
To include the first page of each fax on the fax call report
Use the following steps to include the first page of each fax on the fax call report:
1 Press menu/enter.
2 Use the < or > button to select Reports and press menu/enter.
3 Use the < or > button to select Fax Call Report and press menu/enter.
4 Use the < or > button to select Include First Page and press menu/enter.
5 Use the < or > button to select On or Off and press menu/enter to confirm your selection.
Posted on Feb 13, 2009
    Genius:
  • 2,120 Answers
No, the JOURNALS will only tell you the fax number it was sent to.
HP LaserJet 3330 will not print multiple copies
Does this happen only with some documents/software? I have a different HP printer (a LaserJet) that does the same thing only with PDFs printed from another program. (This happens with PaperPort and browsers using the Adobe Reader plug-in, for example.) If I open Adobe Reader and then open the document in question, I can print multiple copies correctly.
I hope this helps.
Jun 14, 2012 | HP LaserJet 3330 All-In-One Printer
Problems with hp laserjet 3330
suspect either worn ADF(automatic document feeder) pickup roller or there is a jam in the ADF unit where the paper feeds to the scanner.
Mar 11, 2010 | HP LaserJet 3330 All-In-One Printer
Receiving fax confirmation & worded side up or down when sending
  1. Print a configuration report according to the following instructions:
  2. Press MENU/ENTER .
  3. Press the < or the > button to select Reports , and then press MENU/ENTER .
  4. Press the < or the > button to select Config report , and then press MENU/ ENTER .
  5. select the xmit config and choose .
Feb 09, 2010 | HP LaserJet 3330 All-In-One Printer
HP 3330 When I send a multi-sheet fax, it pulls the last few sheets at once. I have to hand feed multi-sheet faxes. Is there sopmething that is worn out? Can I replace it myself? Thanks
It sounds like you need to replace your ADF seperation pad. That's what allows only one piece of paper to pass at a time. The part number for that is C7309-60009, it is recommended that you replace the pick up rollers as well (C7309-60091)If you are looking to do this yourself and save money, shoot me your email address and I can send you a pdf file on how to get everything replaced.
Aug 11, 2009 | HP LaserJet 3330 All-In-One Printer
Describe your hp laserjet 3330 ?
The problem may be in the machine you're sending to, if you get a copy thru the adf or on the glass with no lines, it's the same image you would send thru fax. Check the narrow glass though, I usually find white out on that glass and have to clean it off.
The hp laserjet 3330 diverts to fax too quickly
What you need to do is on the printer, hit the menu/enter button, then scroll through until you see "Fax Setup" click enter, then scroll until you see "fax receive setup", click enter, then scroll until you see "rings to answer". Here can you set it to a higher number of rings, just remember to click enter once you've got the number set to where you want it.
Jul 09, 2009 | HP LaserJet 3330 All-In-One Printer
HP 3330 Scanner is very slow
PDF files are notoriously slow to print. You might invest in more printer memory.
Jan 16, 2009 | HP LaserJet 3330 All-In-One Printer
Hp 3330 line prints on document when faxing or copying
does this problem appear when you copy from ADF? if yes check the rollers, perhaps something stuck on them.otherwise try to clean the glass
May 04, 2008 | HP LaserJet 3330 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
388 people viewed this question
Seeker5211
Seeker5211
