Question about GPX ML848B Digital Media Player
Mini SD Card
What is the right kind of card for it and where can I buy it?
  • Anonymous Apr 04, 2009
    Can't not record music
Mini sd, i used a adapter micro to mini because micro sd is easier to find
Posted on Mar 14, 2009
What kind of memory card do i buy for my jvc gr-d270u
The GR-D270U uses SD cards. They should be available at just about any department, electronics, or office-supply store.
Make sure you get an SD card, not an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Dec 30, 2011 | JVC GR-D270 Mini DV Digital Camcorder
What do i buy so i can attach my digi power dp-fcr20/ mini sd/ms duo card reader/writter so i can attach my mini sd to it and sorry if hard to understand
If the card-reader states it's for a mini-sd card, then you should just be able to insert the mini-sd card into one of the slots. However, some card readers double-up on slots by making it so more than one card-type can be inserted into the same slot. See if the mini-sd card can be put into one of the slots successfully. Tip: Read your manual before doing so, so you don't get card stuck in wrong slot.
Mar 31, 2011 | Computers & Internet
The 4GB memory card my wife baught for my miney com corder is to small and is not going function proply, after closer observation of the card it stated the card was for a cell phone not for a miney...
You can buy an adaptor for the card (I assume you have a micro SD card and your camcorder takes a standard or mini SD card). Try a camera shop for adaptors. It will cost only a little bit more to buy the correct size card.
Mar 07, 2011 | Cameras
What kind of sd card does a polaroid mp3 model pmp280c-4 take.
mini-SD card. Here is a 4gb one on amazon for $7.99 (your device can take up to an 8gb card but make sure you get a MINI SD and not a regular SD.
http://www.amazon.com/Kingston-microSDHC-Memory-SDC4-4GB/dp/B000VX6XL6/ref=sr_1_2?ie=UTF8&qid=1298999885&sr=8-2
Mar 01, 2011 | Polaroid Audio Players & Recorders
How do I download photos from LG VU (CU920) cell phone to my computer?
you can use the bluetooth feature if your computer also has bluetooth capability. if not, hopefully you're using a mini SD card. if your computer has a port for mini SD's, then just take the mini SD out of your phone and plug into your computer. if your computer has a regular SD port, then you need to get yourself a mini SD adapter. it looks just like an SD card, but it has a small opening to slide your mini into. if there are no SD ports on your computer, simply buy yourself a Flashdrive (thumbdrive) that has a port on it for mini SD cards. then, just plug that into your USB port.
if you're not using a mini SD card in your phone, then you need a data transfer cable, which you probably have to get from AT&T. i tried radio shack, but they didn't have them. In my experience, using a mini SD card provides the most compatibility. hope this helps.
Feb 06, 2010 | LG Vu CU920 Cellular Phone
I have a T-Mobile G1 with a micro sd card; trying to sync??
most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader.
You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
Jun 16, 2009 | SanDisk 2GB microSD Memory Card
Problem with the mini SD Card
Thats weird! This is the right size of SD card for your camcorder. http://www.tristatecamera.com/lookat.php?sku=1GBSD80MINI&stsid=CANHG10 Did you try one of the same size?If yes then Did you try an adapter like this one? http://www.nextag.co.uk/INTEGRAL-Micro-SD-Card-1508586241/uk/prices-html?nxtg=16420a280d0a-59E6FEB3CB48EF1E You should get an adapter of appropriate size and place the micro SD card in the adapter and then insert the adapter into the camcorder.
Jun 11, 2009 | Canon HG10 HD AVCHD HD Camcorder
Disk error minisd N73
just find a card reader for sd card , u should have mini sd to sd converter in ur mobile box take it or buy it from street shop , and then put it in card reader in laptop then go to my computer and right click on the card icon in disk section and then select format from the list here u go, but u should first check ur card might be faulty try changing it first
Feb 02, 2009 | HTC Touch P3450 Smartphone
My laptop will not recognize my mini sd card (in adapter) but will recognize a regular sd card
mini sd card may need formatting or adaptor may be faulty.
You can buy a USB stick with SD card adaptor slot instead.
Aug 07, 2008 | Computers & Internet
How to remove write protection in mini sd card? when process in running
I hope this helps - I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!!!!!!!!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now.....don't know why this has to be done, but it works!!!!!!!!!
Nov 09, 2007 | Nokia 3230 Cellular Phone
GPX ML848B  Digital Media Player Logo
91 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
