Question about Kenneth Cole KC1346 Watch for Men
Watch keeps time for days, then suddenly loses 10 or so mins.
Watch keeps good time for several days, then suddenly loses 10 or so minutes over night, requiring reset. Then may or may not run well for a few days. I've had it for a little over a year. Model #KC1346.
  • 203 Answers
SOURCE: my ebel watch loses time
get them to have it checked in their repair shop and tell them its not the battery
Posted on Dec 07, 2008
SOURCE: Losing TIme and Stopping completely!
i think you may need to change the battery!
Posted on Feb 16, 2009
  • 5 Answers
SOURCE: new watch is losing 5 to 15 minutes a day
This could be that the battery is slow. Newer swiss watches have a indicator in the movement of the watch that makes the sweep second hand skip every few seconds to indicate that the battery is slow. On regular japan made watches the watch just simply starts slowing down. Your watch could be new but the battery in it could have a long shelf life.
Posted on Aug 11, 2009
  • 1970 Answers
SOURCE: Watch battery size
mcdevito75 here, Best Bet For correct Battery Number is to call Kenneth Cole T 1-800-KenCole / 536-2653
Posted on Jul 01, 2010
SOURCE: Hi, I've got a automatic
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Posted on Sep 15, 2011
This watch will not keep working. I spin it around and it works for a min. or two.... is there a way to manually wind this watch?
An automatic watch can be wound up by holding them level and swinging it from side to side and several minutes (one maker said swing it 200-300 times).
Once fully wound, the watch should keep working if it is worn daily. Most automatic watches will run for 2-3 days if not worn.
Dec 20, 2010 | Lucien Piccard Automatic Diamond New...
I don't know how to wind the watch....can you help?
WIND AT THE SAME TIME EVERY DAY. This is extremely important. In order to ensure that your watch keeps good time it must be wound at the same time every day. Most people like to do this at night before bed.
WIND ALL THE WAY. The watch must be wound all the way, or it will slowly lose the proper time and require constant resetting. Also, if not wound all the way, the watch may stop keeping time earlier than expected.
WIND IN THE RIGHT DIRECTION. Most European watches wind clockwise when the face of the watch is pointing towards you. Determine which way your watch winds, and stick to that direction. To figure this out, try to turn it both ways. The wrong way will either be extremely loose, or extremely tight.
Tips & Warnings
Keeping your watch clean and free of dust and dirt will also add to its longevity.
Contact the watch's manufacturer for any special and/or specific care methods.
Don't under or over wind you watch. When you start to feel resistance, STOP.
Aug 17, 2010 | Watches
How to adjust a Lord Elgin wrist watch ca. 1950 so that it keeps good time. Currently it loses about 5 min./day.
The first thing I'd recommend for a 60 year old watch is to have a watchmaker clean and oil it. Over the years the oil gets thick and gummy and slows down the watch as you're experiencing. Once it's properly cleaned and oiled the watchmaker will test and adjust it to ensure that it keeps good time. This is not a DIY job but one for a trained watchmaker with the proper tools, lubricants and experience.
Apr 22, 2010 | Watches
Watch erratic. Slows suddenly between days of working well.
Sounds like a failing battery to me. Its very common for a watch to loose time when battery needs to be changed.
Jan 09, 2010 | Timex Watches
Analog hands lose time when worn.
This is usually a indication that the minute hand is slightly loose on its pinion. This requires that the hand be tightened, so that it does not slip. Best left to a watchmaker.
Nov 23, 2009 | Casio AMW320R 1EV Casual Sports Watch
Bulova has mechanical day/date display near 3 o'clock position, electronic watch (quartz I presume) less than 3 yrs old. Started losing time. I assumed the original battery needed to be replaced. Battery...
I believe you are just outside your warranty. Its time to see a watch maker/technician about repairing the watch. Often times slowing is as easy to fix as lubricating the movement and forcing the gear train through the use of a cyclonic device. This fix takes minutes and is very cost effective. If the slowing is due t circuit board issues or a more sever gear train problem then the movement will need to be overhauled. I suggest comparing this cost to the cost of a replacement movement.
Sep 22, 2009 | Bulova Watch
Omega Seamaster gaining about 10 minutes per hour
Hi honestfunguy. Take it back! Omega watches are usually guaranteed for 2 years or even 3 years (Co-axial escapement), so you should not have a problem getting it repaired under warrantee. No way should it be be gaining (or losing) 10 minutes per day, let alone 10 minutes per hour. Could be any number of things, from a broken mainspring to problems with the timing regulator, but they are very complex watches and should not be looked at by anyone apart from Omega whilst in warrantee, otherwise you'll probably void the warrantee. Hope this helps; Eagle58
Jun 07, 2009 | Omega Seamaster 300M Auto 2531.80.00 Wrist...
All my watches losing time
good day,
hope this link below will solve your problem.
Feb 25, 2009 | Skagen 355LGSC Wrist Watch
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
My ebel watch loses time
Dec 02, 2008 | Ebel 1087902 wristwatch
Kenneth Cole KC1346 Watch for Men Logo
82 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
