Question about Philips GoGear Flash MP3 Player
Ipod wont recharge.
When the Ipod is turned on after charging for some considerable time, it flashes the battery and shuts down. Ipod is no not recognised, even as a removeable disk drive.
Greg
  • g_mcivor Feb 13, 2009
    Thanks Rockitman. Should have been obvious, but it is relatively new and not used that much. Still, will try.
    Regards
    Greg
    President:
  • 2,559 Answers
You need a new battery,Take to your local apple store or go on line and get the battery kit for yours and you can do it yourself.
Please rate this a fixya
Posted on Feb 13, 2009
Battery cannot be recharged.
OK, Batteries have cycles and these get depleated by recharging thus once there all gone well the battery will not charge. The facts here 9 timeso ut of 10 it would be the battery but I will not holdthat over your head. Take it to a camera shop and discover it for yourself as what you going to end up doing anyhow. If it where the charger I would reckon it would not even try the first time.
Thanks and please be considerate when leaving a postive rating and feedback
May 27, 2010 | Samsung NV10 Digital Camera
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
NS-DCC5HB09 High Definition Flash Media Camcorder: mine wont turn on and i dont have a charger!!! Hel...
You should be able to recharge this unit by connecting to your PC and charging through your USB connection.
If your battery is faulty or unable to recharge, here's a replacement battery that's available:
http://bestbuy.partsearch.com/GetModel.aspx?MfgName=Best+Buy+Company+Incorporated&BrandName=Insignia&ModelNumber=NSDCC5HB09&Page=1&SortBy=brandname&SortDirection=asc
Just about any AC to USB charger will work to recharge this unit, so if you have an iPod with the iPod wall charger, use the correct USB cable with the wall charger and you will be able to recharge the battery in the camcorder.
Hope this helps!
May 11, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Why wont my ipod touch turn on i turned it off and it wont come o
Hold the power button and home button for 10 seconds to ensure the device is off. Let go.
Hold the home button down, plug in the ipod to the computer, after the screen changes to the itunes plug screen, let go of the home button.
The ipod will now be in recovery mode, and you can attempt to perform a restore within itunes.
If the restore fails, and the ipod screen stays black, this means the battery is dead and must be replaced.
Oct 22, 2009 | Apple iPod touch
Phone shut itself down, won't come back on
how old is the phone and more specifically, the battery? rechargeable batteries, unfortunately, do not last forever. i used to have a phone that didn't need charging for days. over time (a few years), i had to charge every night.
will it turn on while plugged in? if so, then it's probably the battery.
Oct 22, 2009 | Samsung Jack Cell Phone
Override Dell Latitude D600 laptop automatically shutting down
yes there is, go into control panel>power options and choose how long you want the display and computer to stay on for before going on standby.
Turn of the display> change to four hours
Put the computer to sleep>choose never or select a suitable time for when the computer should sleep
I hope this helps
Jan 10, 2009 | Dell Latitude D600 Notebook
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Ipod not turning on/not recharging
Have you tried holding down the menu button and the middle circle button?
first place your ipos somewhere flat and press down the circle button and the menu button,make sure your not touching any other part of the click wheel.hold them down for about 5 seconds untill the apple logo appears.then let go,and it should be back to normal.you can use this procedure any time that it freezes or stops working.Hope fully that should fix your problem.if not i suggest you get it repaired under your warrenty.
Good Luck.
Regards.
Sophie
Feb 13, 2008 | Apple iPod nano 3rd Generation
Blank and wont charge
Try the "Five R's" as found on Apples website. If still no go, then it's probably time for a new battery or a new Ipod.
Nov 08, 2007 | Apple iPod nano
Philips GoGear Flash MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
