I just bought a used Pasquini Livia 90. It's one of the older versions; serial number 386 if you can...
(More)
I just bought a used Pasquini Livia 90. It's one of the older versions; serial number 386 if you can believe it.
There are several problems with it. When I first plugged it in it warmed up and expelled steam from the bottom release valve for about 2 minutes. Once it stopped I tried the hot water wand and some dirty water came out, but then it stopped; maybe two tablespoons worth. I tried the brew switch and some steam and water came out of the grouphead but again not much. The steam works fine. In addition, after it warms up if I leave it for a few minutes and press the brew switch it doesn't light up and nothing happens. If I open the steam valve then the light comes on on the brew switch. It will then make noise on and off as I turn the brew switch on and off, but eventually stops and sometimes stays on with the switch off, and sometimes stays off. I looked inside and don't see any loose connections but unfortunately I've never owned one of these before so I'm not sure what it SHOULD be doing, or should look like. I also don't have a service or user's manual. Any thoughts?
Same issue with door handle breaking off on the Samsung SMH7185STG model. Will try to order...
(More)
Same issue with door handle breaking off on the Samsung SMH7185STG model. Will try to order replacement parts unless there's a better option. This is really a defective model. We bought the Samsung based on it's reputation, but they clearly missed the boat on this model.
