Question about Jenn-Air Microwave Ovens
Power goes off, then on, then off...
I offer my amateur services to the elderly in my community. One of them has a built-in Jenn-air microwave over the range (not part of the range) with a date of September 1981 on it.
The model # is M14001.
The symptoms are these:
It quit working (both clock and cooking), then after a week, it mysteriously started working again…for more than a month. Then everything went out again…until last night. During a wind storm, the power for the whole community went off and on a few times, and now it is working correctly again.
My assumption is that the connection to power may be loose, but I don’t know how to access the area of the microwave where that connection is. I am guessing it might be through the sheet metal cover on the bottom…just not sure.
There is no external receptacle or plug. I double checked the wiring to the circuit breaker, and it is solid.
Based on the above symptoms, do you concur that it is likely the power connection rather than something to do with the microwave itself? If so, can you tell me how to access the power connection area of the microwave?
Also, in case it becomes necessary, can you guide me as to how to remove the microwave? I can’t see any way to remove the microwave if it needs to be replaced. There are no external screws on or near the microwave, and nothing inside the adjacent cupboards.
Thank you so much.
Steve Divnick
1-937-384-0003 (Eastern)
  • steve530 Feb 14, 2009
    William,
    Uh oh. Your email must have gotten caught in my spam-blocker.
    Can you please resend it?
    What is the subject and "from" address. I will watch for it.
    Thank you.
    Steve
  • Jenn-Air Master
  • 9,086 Answers
I answered this via e-mail.
Let me know if you need more help or how it goes.
William E. "Ed" Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Feb 14, 2009
Manual for jenn air microwave jmc8130dds
Like most manufacturers these days, Jenn-Air offers manuals online. I did not see specific instructions for removing the panel, but here is a link to the parts diagram which may offer some hints. You can also call or chat online with Jenn-Air Customer Care.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20JMC8130DDS.pdf
Jan 01, 2015 | Jenn-Air JMC8130DDS Microwave Oven
Jenn-air jmv9169ba will not heat
I hope you are a technician as there are lethal voltages inside a microwave , you could also inadvertently expose yourself to microwave radiation if protective switches are disabled or the door seals are damaged .Open the microwave top cover, disconnect the two wires going to the Power Transformer (The Big one) and connect a Dummy Bulb and Power up if the Bulb goes ON and OFF according to your settings, the control Panel is OK, or else replace .Check the High voltage diodes, Protector Diodes and the high voltage capacitors , if they are OK the magnetron is suspect. The high voltage transformer rarely fails. If the microwave is of the inverter type , forget it, it is not for amateurs to repair.
Jul 08, 2014 | Jenn-Air JMC7000 Microwave Oven
Jenn air microwave quits working after 11-13 seconds of heating
open circuit switch when power reaches this switch it will shut down as switch is us
Aug 12, 2012 | Jenn-Air JMC8127DD Microwave Oven
My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model...
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
NAR_JennAir_CustomerExperience@JennAir.com
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
Oct 26, 2010 | Jenn-Air JMV8208A Microwave Oven
Jenn-air microwave dead
I'm afraid since Jenn Air has become a division of Whirlpool (along with numerous others) the quality has suffered.
I was going to suggest that you purchase a service manual for your unit so you could 'reset' it yourself. Service manuals can cost from $12-$40 US and in many cases obviate the need for 'professional' service calls. However, I couldn't find one offered for your model number so your only choices are to continue to pay for 'service' or examine the guts visually to see if you can locate any reset feature. This is what I would do.
When microwaves fail, older ones generally need a diode, a big capacitor or the magnetron replaced. Newer units are suffering power supply failures as many have moved from the reliable but less efficient 'linear' power supplies to 'switched mode' types that are more efficient but more complex and prone to failure. These later types usually have the word 'inverter' in the model description.
Jan 04, 2009 | Jenn-Air JMC8130DD Microwave Oven
My jenn-air microwave makes a LOUD humming noise
More than likely the power inverter board has been damaged and it would be best to stop using it immediately.
Jenn-air products are very good quality and quite expensive to replace. I would contact Jenn-air service and have a service tech dispatched to determine the exact problem and the cost to repair it. Jenn-air stands behind their product 100% and should be able to repair the unit for you.
http://www.jennair.com/content.jsp?name=local_service_repair
Follow this link to Jenn-air service and repair.
Cheers,
Keith
Jan 02, 2009 | Jenn-Air JMV8208AAS Microwave Oven
Home warranty company saying JennAir M166 built in microwave isn't a true built in
Bottom line is... Home warranty companies will do anything possible to wriggle out of paying for something. (Especially if it's American Home Shield).
I'd suggest offering to fax / email photos and the front cover of your owners manual. Your model is 100% considered a built in unit and they are lying to you and trying to cheat you if they say otherwise.
Aug 24, 2008 | Microwave Ovens
Jenn Air JMC7000ADW
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
May 01, 2008 | Microwave Ovens
Jenn-air microwave JMC 7000 ADB has no power
I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
