Question about Whirlpool LER5636P Electric Dryer
Lint on Clothes
I do not dry my shirts. Even though I try and be very careful to sort the clothes correctly, my shirts always have lint on them. Any suggestions of what can be used in the washer to help prevent the lint?
  • 686 Answers
When you wash clothes, they lose fibers from the agitator and unfortunately when you hang dry them the fibers from eachother or other articles of clothing stick to it making them look like they have lint on them. Drying them in the dryer removes this lint. I suggest drying them in the dryer and to prevent wrinkles hang them as soon as possible after dryer stops other than that I know of no solution in the wash for this problem. Good Luck.
Posted on Mar 02, 2009
Frigidaire gleq442ces0
I had this same problem 3 weeks ago, and here is what I found.
The dryer was so clogged with lint it could not dry the clothes. I had to take the whole machine apart and clean all the lint out. I found the felt around the drum was worn out, and that was allowing the lint to go everywhere it shouldn't. With the felt replaced and the lint gone, it worked well.
Be blessed.
Jun 23, 2013 | Dryers
Tip
Dryer Taking too Long to Dry Your Clothes?
A very common issue we deal with on FixYa is clothes dryers that are taking too long to dry clothes. Here's a few tips on keeping your drying time to the minimum.
1. Check and empty your lint trap before each load. If air flow is restricted, your dryer will need longer to get the job done. A clean lint trap will allow for maximum intake air to the dryer blower.
2. Check the exhaust ductwork for lint buildup. If the 4" ductwork that carries your warm, moist, lint-laden air to the exterior of your home is blocked with years of lint and moisture, chances are pretty good your dryer is taking longer than it should to get your clothes dry.
  • Disconnect the dryer power cord (and gas line if a gas unit), slide the dryer forward far enough to access the 4" ductwork clamp at the back of the dryer. Disconnect the ductwork at the dryer and separate to inspect both in the dryer exhaust duct and the ductwork as well.
  • Remove all built up lint. You may need to access under the floor, or in the crawlspace, or basement to get at all the areas that lint may be built up. Remember that when there's an elbow (turn) chances are pretty good there's lint in there, so take the time to separate the ductwork where needed to give it a thorough cleanout.
  • Long straight sections of ductwork can be easily cleaned by purchasing a "webster" style pole brush.
  • Clean the exhaust duct of the dryer but be careful not to damage anything inside your dryer
  • Reconnect and turn the dryer on air fluff to blow the rest out.
3. Remove lint build up from inside the machine
  • Turn power off again
  • Remove the front cover of your dryer
  • Remove the front drum support/air duct from the front of the dryer
  • Carefully vacuum the lint out of the dryer with soft brush attachment on your vac. Be careful not to damage any ignitor or electrical items.
  • Clean the inside of the lint trap duct of sediment/ buildup
4. Make sure your washing machine is spinning the water out of your loads correctly. This one is pretty obvious, but it bears mentioning.
If your clothes feel wetter than normal, it's definitely going to take longer to dry. Be sure to wash "like" items. A medium/large load of towels is better than a towel and 5 cotton shirts ( that towel will throw the load off balance and your machine won't spin as fast to get the water out).
5. Medium-sized loads dry faster than mega-large-cram-it-in loads.
The idea of getting all you can into a dryer (or washer) to save time and money will end up costing you both time and money. I've seen this played out many times in my laundromats: You will find that a medium, loosely packed load will dry faster and with less wrinkles and less ironing needed.
Using these guidelines will help keep your drying times to a minimum and also allow your machine to work for many years to come.
on Dec 03, 2009 | Dryers
Excessive lint on washed clothes
Your washer does not have a lint filter, so it's very important to sort lint givers from the lint takers. Washers today to not have lint filters because we rely on the dryer to remove lint that does not get pump out with the wash water.
Below are tips taken directly out of the user's manual:
  • Did you sort properly? Sort lint givers (towels, chenille) from lint takers (corduroy, synthetics). Also sort by color.
  • Did you overload the washer? The wash load must be balanced and not overloaded. Clothes should move freely. Lint or powdered detergent can be trapped in the load if overloaded. Wash smaller loads.
  • Did you select the correct water level? The water level should be correct for the load size. The load should be under water.
  • Did you use enough detergent? Follow manufacturer's directions. Use enough detergent to hold the lint in the water.
  • Did you line dry your clothing? If so, you can expect some lint on the clothing. The air movement and tumbling of a dryer removes lint from the load.
  • Was paper or tissue left in the pockets?
  • Is your water colder than 60°F (15.6°C)? Wash water colder than 60°F (15.6°C) may not completely dissolve the detergent.
  • Did you use the proper cycle time and agitation speed for the load? Reducing wash time (duration) and agitation speed are ways to reduce lint.
Jan 10, 2011 | Maytag Atlantis MAV6000 Top Load Washer
We have a combo dryer and washer. Washer is A2444330KH. Leaves lint on cotton shirts, have cleaned the filter no help. Any ideas? David
Dryer lint not only presents a problem by cluttering up your clothes with white specks, but it can also lead to a dryer fire. While it is impossible to completely eliminate dryer lint, you can take action to drastically reduce lint and the potential problems that come along with excess dryer lint. If your clothes take more than one cycle to dry, you see no lint on the lint screen, the clothes are very hot after drying or you find excess lint on the clothes after drying, you probably have a problem with accumulation of dryer lint in the dryer vent.
Use a dryer vent cleaning brush and clean the dryer vent, or hire a professional to clean the exhaust vent behind your dryer. If your dryer vent is clogged, it will create excess dust in the dryer and on the clothes. The excess lint can eventually catch on fire given the heat load of the dryer.
Dec 05, 2010 | Maytag Washing Machines
All my shirts are ending up with fuzz balls . Is there a lint filter?? i can't seem to find it .
There is no lint filter. Make sure you have enough water to float the clothes. Try washing your shirts with the permanent press or gentle cycle.
Nov 20, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Prblems with Kemore washer
Clean your washing machine before your next wash load to be sure there is no lint trapped anywhere in the machine. Fill the tub about half full of water then add a couple of cups of white vinegar to the wash water. Allow it to agitate and then sit there and soak for at least an hour before you empty the machine.
Lint is small fibers from clothing that have come loose from natural wear or laundering. They can build up in washers and wreak havoc on your clothing. The dryer will remove the lint. But with clothing, like dress shirts that are air-dried, this can be a real problem; often requiring multiple washings to remove the lint. Older washers came standard with removable lint traps that could be cleaned. Some would filter the water as it recycled through the washer, while others would require the removal of the center tub support for cleaning.
Newer washers have a self cleaning system that uses a filter to trap the lint and the spin cycle to flush it away. It saves the inconvenience of having to manually clean the filter.
If you have a lint problem, here are a few tips to try:
1) Low water pressure can impede the flushing action of the washer during the spin cycle. Look for pressure variations during filling of both hot and cold water. A kinked or blocked hose can cause this. Check for sediment in the hose as well.
2) Verify that the all of the water is being pumped out of tub and that no restriction in the drain hose exists.
3) Don't wash high lint producing items like socks and towels with your dress shirts.
4) Use a name brand detergent. They have higher quality cleaners and soften the water better, which helps release the bond between lint and clothing, allowing it be flushed away.
5) Don't overload the washer. Your washer needs water and room to remove the lint.
6) Run a wash cycle with a cup of regular white vinegar added. This will help rid your washer of any accumulated lint.
A washer doesn't produce enough lint to have any effect on a septic system, so a separate washer filter is not necessary.
Add a cup of either white or cider vinegar to your washing machine along with the detergent before loading in your clothes to keep lint off.
Sort out all towels and washcloths since they create lint. Put them through a separate wash cycle to keep them from transferring lint to your clothes.
Check the labels on all your clothing to be sure you sort them correctly. Cotton clothing produces lint in the washing machine while polyester clothing picks it up. Wash them at different times to keep the lint off those that are likely to pick it up.
Turn your clothes inside out before putting them into the washing machine to keep them from collecting lint as they go through the wash cycle
Jun 18, 2010 | Kenmore 24032\24036 Top Load Washer
Lint collecting and sticking on some clothing
Did you sort properly? sort lint givers(towels) form lint takers(syenthetics)
did you over load the washer? the wash load must be balanced clothes should move freely in the water
did you select to correct water level?
did you suse enough detergent? use enough detergent to hol the lint in the water
Did you line dry your clothing? if so you can expect some lint on clothing?
check the following:
was paper or tissue left in the pockets
is your water colder than 70 decrees F washe water colder than 70 decrees may not completely dislolve detergent
did you use the proper cycle time for the load? reducing the wash time is another way to reduce lint
Jul 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
6th cycle and clothes are still extremely wet.
Are you cleaning the lint filter after each load?
(Pull it out of the top of the dryer or inside the door and clean it )
Can you go outside and find the vent where the dryer exhausts air? when the dryer is running with clothes in it, is there air coming out? If not, It is plugged.
Whether you think it is pluggged or not,, go back inside and pull the dryer out from the wall carefully. If it is a stack job, get help!
Now the 6" diameter rippled tubing that connects from your dryer to the wall can be removed by loosening the clamp on the dryer with a screw dryer. I think you should carefully unplug the dryer before you start this!
Loosen the clamp and pull the hose off the back of the dryer. It may be full of lint and all sorts of interesting things which you need to clean out. Or you may find that it is not even connected. When you are satisfied that it is clean. place it back on the dryer (MAKE SURE it is not twisted) and tightened the clamp back on very well with the screwdriver. When you push the dryer back in place be careful not to push it in so far that you collapse this vent hose or twist it.
That's the dryer. NOW, when you remove the clothes from the washer do they feel still full of water? Is the washer spinning well and removing most of the water? If it is not this can cause your dryer to take forever to dry the clothes and it can also cause your dryer to overheat.
Whether you have a pile up of lint in your lint filter and hose or the washer is not spinning correctly, both are a huge fire hazard for the dryer, so TAKE CARE of this NOW. Please. and Good luck!
Aug 12, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
65 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
