Question about D-Link AirPremier DWL-2700AP 802.11g/b Wireless Access Point
DWL 2700 AP wrong firmware install
Hi I have a DWL 2700AP I install wrong firmware this device. Now power led blinking every time I am open case and hard reset device. But problem not solved. Pls help me.  Sory for bad English
  • GeminiBS Feb 14, 2009
    Have a D-Link DWL 2700 AP.
    H/W version A3
    F/W Version 1.02
    I just upgradet the firmware version to 2.0 Ax.
    The "power" led is blinking as soon as i plug the RJ45 and i cannot access the device at all.
    Any ideas?
    Thanks
  • Anonymous Mar 10, 2009
    how to hard reset the router. since there is no button provided and you cannot access the router using network, how to hard reset the dwl-2700ap ver A3
    Scholar:
  • 54 Answers
Hi...
since you upgraded a different firmware try updating the firmware again with the correct firmware if it works fine if it doesnot then the router had gone bad,,
and for GeminiBS reset the router to the factory default since the firmware was not done in a proper manner may be it had interruptions..once the hard reset is done the computer is restored back to the default so that you can use the device..
vedhick
Posted on Feb 16, 2009
I have a motorola AP-300 which keeps on blinking amber light when i turn it on. how can i reset it or what's wrong with the AP?
From the installation guide for this AP, I find the following:
LED Indicators
The unit has LED activity indicators on the front of the case provide a status display indicating error conditions, transmission, and network activity for the 802.11a (amber) radio or the 802.11b/g (green) radio.
802.11a Activity LED Amber
The amber LED flashes three times per second until firmware is loaded. During boot, 802.11a mobiles cannot associate. After adoption, the amber LED is steady or flashes with 802.11a radio traffic.
The amber LED flashes once per second if an error prevents the 802.11a radio from operating normally.
802.11b/g Activity LED Green
The green LED flashes three times per second until firmware is loaded. During boot, 802.11b/g mobiles cannot associate. After adoption, the green LED is steady or flashes with 802.11b/g radio traffic.
The green LED flashes once per second if an error prevents the 802.11b/g radio from operating normally.
From this, it appears that the 802.11A radio is malfunctioning.
Here is the Motorola support web page for this device.
Dec 30, 2010 | Motorola AP300:802.11A/G, Internal Antenna...
DWL-2700AP reset default settings
Remove 13 screws from the perimeter of the back side of the DWL-2700AP and pull the covers apart. On the inside along the bottom adjacent from where the network cable plugs in, you will find a reset button. It is next to the white plug that leads to the antenna. You will need a flat screwdriver or something thin and sturdy to wedge between the casing and the reset button. While the AP has power, press the button and hold it in for a few seconds then release. Give it a few minutes and the factory defaults should be restored. Default IP: 192.168.0.50, Default subnet mask: 255.255.255.0
Jul 18, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Reset DWL 2700AP to factory defaults
Hi dear try to flow this tips it will help you
Administrator Settings
Administrator settings allow you to customize User Name and Passwords as an Administrator of DWL-2700AP. The default value of the Username is "admin" with no password entered.
Password
Enter a password in the Access Point Password field. Type the password again in the next field to confirm it. The Password is case-sensitive ("A" is a different character than "a",) and must be between 0 and 12 characters in length
System Settings
You may reset the DWL-2700AP back to factory settings by clicking on Restore Default settings.
Restore Default Settings
Choose Yes and click Apply to restore all Access Point settings to the factory default settings.
Thank you
Imran
Pls rank as possible
Apr 20, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
DWL 2700 AP power light flashing, no IP
Yeah, not a good idea to have opened it if there is a warranty still in effect. Belkin, DLink, and Linksys are all made by the same corporation, Cisco, and generally a flashing power light indicates a fault condition. You may be better off getting a new one.
Dec 19, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
Dwl-2700ap problems
hello!
-- try to change channel and enable security on your wireless network
-- remove other wireless devices on the network because that may cause wireless intermittent in your network
Apr 30, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
How to probe the configuration or reset the 2700AP?
Restore it to default, with these things, if it wont work on automatic, then something is worng.
Feb 27, 2008 | D-Link AirPremier DWL-2700AP 802.11g/b...
Power light remain blinking
hi, i noticed before when i pressed on the reset button of my dlink, the power started flashing, n when i stopped pressing the reset button it wont stop flashing anymore..did you happen to press the reset button or power button too long, sometimes it is dislocated so the power light wont stop flashing, just by pressing on it one more time should fixed it, though if it was previously configured it will go back to default settings...thats also the reason why you cant ping or go to the config page because its not relaying the info..i stongly suggest you contact dlink for this so that they could give you more info about it...because for power light its just that or its already defective...i hope this would help, pls feel free to ask if you have anymore questions
Nov 29, 2007 | D-Link AirPremier DWL-2700AP 802.11g/b...
DWL 2100AP problem
If you can get into the built in webpage to upgrade firmware I would suggest upgrading it. Sounds to me like corrupted firmware. If you can I would return the device. I had a similar issue with a linksys AP and I found out that the Firmware was scrubbed. Had to send it back to the manufacture.
Jun 18, 2007 | D-Link AirPro DI-764 Wireless Router
3crgpoe10075 status led blinking with no stop
hi ,,, i got yor problem. as ya said its not allowing ya to log nto it with security enabled. Ya can try to log into it with the ethernet cable as their wil be an ethernet LAN port onthe access point. I f ya know the default or the present ip of AP then ya can assign a static ip of the same range to yor computer like eg. ap is 192.168 .1.1 then your comp can have 192.168.1.10 and ya can log into it thru the ethernet cable and disable the security. i hope ya know how to assign a staic ip add to yor compuetr. or check the screen shots on brivers.com n select the "network connections" screen shots to assign a static ip address to yor' comp. feel free to chat with me on samrat101 thru yahoo or msn messenger or drop a mail on samrat101@yahoo.com for ny wless n ipphone issues -- take care ,, samrat
Nov 23, 2006 | 3Com OfficeConnect 802.11g/b Wireless...
D-Link AirPremier DWL-2700AP 802.11g/b Wireless Access Point Logo
801 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
